Ibiza 6j oem xenon upgrade problem
matej.zibar
Post by matej.zibar »
i have Ibizu 6j fr 2.0 tdi with headlights in which h7 bulbs i install oem headlights with xenon, now when the light switch is in position 0 I don't have high beams I just hear the lens open into the headlight, it also doesn't work my drl because I don't know where the wires connect. Has anyone done this before and has experience?
Re: Ibiza 6j oem xenon upgrade problem
yes, i've installed many oem xenon conversions in ibiza 6j. do you have a tool like vcds to read and change the coding of your bcm?
