hi all
not strictly a polo but pretty similar and after some help if possible!
2010 vw polo that has lost its abs module coding!
can anyone generate a long code for the module with the following code scan!
thanks in advance
Wednesday,17,February,2021,16:14:02:49450
VIN: VSSZZZ6JZAR063240 License Plate:
Mileage: 145440km-90372mi Repair Order:
Chassis Type: 6J (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZAR063240 Mileage: 145440km-90372miles
03-ABS Brakes -- Status: Malfunction 1010
4B-Multifunc. Module -- Status: OK 0000
Address 01: Engine ( ) Labels: None
Part No SW: 03C 906 057 CA HW: 03C 906 057 M
Component: BOSCH ME7.5.20 2775
Revision: 21H05--- Serial number:
Coding: 0000071
Shop #: WSC 06402 785 00200
VCID: 65C1DBF2AFA0EC6A33-5140
3 Faults Found:
049441 - No Communication with ABS Brake Control Module
U0121 - 008 - - Intermittent
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 145444 km
Time Indication: 0
Date: 2015.07.11
Time: 21:55:43
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 64.0°C
Temperature: 22.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
001281 - Vehicle Speed Sensor
P0501 - 004 - Implausible Signal
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 145444 km
Time Indication: 0
Date: 2015.07.11
Time: 21:55:43
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 64.0°C
Temperature: 22.0°C
Voltage: 0.000 V
050197 - Implausible Data Received from ABS Control Module
U0415 - 008 - - Intermittent
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 145444 km
Time Indication: 0
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 41.0°C
Temperature: 25.0°C
Voltage: 0.000 V
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 AD HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0001
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 04941 000 00000
VCID: 000FEA6697C22942A0-8054
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 5
Reset counter: 215
Mileage: 145444 km
Time Indication: 0
Date: 2015.07.11
Time: 21:29:48
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x3213
Hex Value: 0x1499
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7F00
Hex Value: 0x0000
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 HW: 6J0 820 045
Component: J301 Klimaanlage 0280
Revision: 00 23 08 Serial number: 0000000286454-
Shop #: WSC 00000 000 00000
VCID: 63C5C5EAA294925ADD-8036
2 Faults Found:
01316 - ABS Control Module
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 0
Mileage: 145444 km
Time Indication: 0
Date: 2015.07.11
Time: 21:37:43
00705 - Relay for Coolant Fan; Stage 1 (J279)
009 - Open or Short to Ground
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 29
Reset counter: 215
Mileage: 145444 km
Time Indication: 0
Date: 2015.07.11
Time: 21:37:43
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 B HW: 6R0 937 087 B
Component: PQ25 BCM H09 0029
Revision: BF009001 Serial number: 9955A251092824
Coding: 24882BE888610100003000007E0B1CC80040400F608C00002000
Shop #: WSC 47699 476 96594
VCID: 3C775E96BFAA8DA2BC-8068
Subsystem 1 - Part No SW: 6R0 959 802 HW: 6R0 959 802 Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 001 0239
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 B HW: 6R0 959 801 B Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 001 0243
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 811 HW: 6R0 959 811
Component: J388__TSG_HL 001 0245
Subsystem 4 - Part No SW: 6R0 959 812 HW: 6R0 959 812
Component: J389__TSG_HR 001 0246
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10AirbagA0D H09 0018
Revision: -------- Serial number: 003DW006HE43
Coding: 003044
Shop #: WSC 06401 785 00200
ROD: EV_AirbaVW10BPAVW250_VW31.rod
VCID: 428B206ED54EFB52F6-8016
Serial number: 3496GRB402F9GRDKTBFM
Serial number: 3506GRB401L9GRDL0C3N
1 Fault Found:
12656896 - No Communication with ABS Brake Control Module
U0121 00 [008] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 0
Mileage: 145444 km
Date: 2021.02.17
Time: 22:04:05
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6J0 920 901 HW: 6J0 920 901
Component: KOMBI H07 0110
Coding: 410A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 65C1DBF264A0EC6A33-8030
1 Fault Found:
12656896 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Priority: 6
Fault Frequency: 2
Reset counter: 0
Mileage: 145444 km
Date: 2021.02.17
Time: 21:55:28
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087 B
Component: GW-K-CAN TP20 0029
Coding: 022300
VCID: 70EFBAA6A36239C250-8024
1 Fault Found:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 0
Mileage: 145444 km
Time Indication: 0
Date: 2015.07.11
Time: 22:04:13
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H07 0110
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10121
Shop #: WSC 06402
VCID: 2E5364DEEDD66F3202-807A
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Coding: 0000001
Shop #: WSC 77005 000 00000
VCID: 70EFBAA6636239C250-8024
Address 56: Radio (J503) Labels: 6J0-035-153.clb
Part No SW: 6J0 035 153 B HW: 6J0 035 153 B
Component: Radio G3 UL H56 0034
Revision: 0H001001 Serial number: SEZ1Z2I6327509
Coding: 0503040002
VCID: 234585EA2214D25A9D-8076
1 Fault Found:
00625 - Vehicle Speed Signal
Fault Priority: 6
Fault Frequency: 2
Reset counter: 0
Mileage: 145444 km
Time Indication: 0
Date: 2015.07.11
Time: 22:05:06
End-------------------------(Elapsed Time: 02:20)--------------------------
abs 8.2 long coding needed!!
Re: abs 8.2 long coding needed!!
Is this a polo or an Ibiza?
its an ibiza
cheers
cheers
can you help with this?
cheers
cheers
Probably, but it might take a while.
