This is driving me nuts. I have a subtle knock coming from the drivers side (RHD) and its only there when the suspension is floating. When I say floating I mean, it wont make the knock when going over bumps or dropping, its when the road surface is slightly uneven and feels loose.
I replaced the tied rod arm and the track rod end and since then it has had an MOT with no advisories.
You really notice it when you drive over cobbles
Can I rule out drive shaft as there is no slop when moving back and forth?
Must try and identify this problem at the weekend
Any suggestions greatly appreciated
Cheers, Andrew
