Recommended auto light switch
Saw in some posts here about these chinese aftermarket auto headlight switch, Unfortunately I bought a bad one..
So I saw most of the old post talk about these 2:
https://www.aliexpress.com/item/4001096 ... web201603_ The bluetooth one..
https://www.aliexpress.com/item/3289237 ... 5613%23462
I think they are also sold on Amazon and other sites but basically these are the same products.
Which of them is recommend? Or is there a specific product you recommend (non OEM)?
It seems like the bluetooth one should have the most setting options (always on and etc..)
Re: Recommended auto light switch
I've heard a lot of people having issues with 3rd party auto light switches not being able to get Coming, leaving home working and auto light.
Maybe on indian forums you could find the right one that will work
Which Indian forum?
The OEM auto light is to expensive and complicated to install for me..
Try seaching for "bend pin 1") you dont really have to bend pins if you have yo just isolate them thinly.
Search more, this is just a hint
I installed the non-bluetooth version in my 2015 GTi. Dead easy to install and I've left it on auto since then and not thought about it. I would recommend.
- SimonPoole
I installed the Bluetooth version in my son's 2012 Match and it's pretty good to be honest.
Only downside is that the app doesn't seem to be compatible with the latest Apple iOS, but I have an old iPhone lying about that I can still use.
- mirceaculita
- Drives: 6R 1.2TDI 75hp
I think the bluetooth one is only compatible with old android and ios versions.
- mirceaculita
Are the coming/leaving home features working as intended? Also where did you route the light sensor and how reactive is it?fleagal wrote: Fri Mar 12, 2021 2:43 pm I installed the non-bluetooth version in my 2015 GTi. Dead easy to install and I've left it on auto since then and not thought about it. I would recommend.
I'm not sure what the intended function of the coming/leaving is although the lights do stay on for a few seconds after the car is locked and when the car is unlocked. I think that is what you mean?
The only unintended side-effect is that when the light drops below the standard darkness threshold the lights will coming on for a few seconds even if the car is locked and alarmed. It doesn't cause any problem although it took me a while to realise that no-one was sitting on my keyfob or was trying to steal my car!
From memory I took the panel off near the steering wheel and routed the wire up onto the dash. I was prepared to use some force and unscrew a load of panels but it transpired that the wire was thin enough and the gap between the panels malleable enough that I just pushed it through and sat the sensor atop the dash. You can't see it from the driver's seat but can see it if you are outside and looking directly downwards onto the very front of the dash at the bottom corner of the screen. Very neat.
- mirceaculita
fleagal wrote: Mon Mar 15, 2021 4:47 pm The only unintended side-effect is that when the light drops below the standard darkness threshold the lights will coming on for a few seconds even if the car is locked and alarmed. It doesn't cause any problem although it took me a while to realise that no-one was sitting on my keyfob or was trying to steal my car!
So you are basically saying that when the car is turned off and it gets dark, the headlights will turn on for a few seconds? That's kinda dumb imo
I guess since the light switch is always powered the sensor doesn't turn off. That's just lazy programming tbh...
Saw a lot of posts about using this switch: https://www.aliexpress.com/item/1005001 ... piIRo&mp=1 on the VW T5, it's the same connector as the Polo's.. Maybe it's less buggy then the Bluetooth one?
I think my current switch does it too sometimes, but the leaving-home function is not always working so it's very annoyingfleagal wrote: Mon Mar 15, 2021 4:47 pm The only unintended side-effect is that when the light drops below the standard darkness threshold the lights will coming on for a few seconds even if the car is locked and alarmed. It doesn't cause any problem although it took me a while to realise that no-one was sitting on my keyfob or was trying to steal my car!
That looks like the one I have.EdenBanim wrote: Tue Mar 16, 2021 11:27 am Saw a lot of posts about using this switch: https://www.aliexpress.com/item/1005001 ... piIRo&mp=1 on the VW T5, it's the same connector as the Polo's.. Maybe it's less buggy then the Bluetooth one?
Yes but for the reward of never having to switch my lights on or off it's worth it.mirceaculita wrote: Mon Mar 15, 2021 9:31 pm So you are basically saying that when the car is turned off and it gets dark, the headlights will turn on for a few seconds? That's kinda dumb imo![]()
Thinking about it though it could be that power is cut to the lights when the CANBUS system goes to sleep which is, what, 10 minutes? I live close to work and often get home before it gets totally dark so maybe it only occurs when I get out of the car before the darkness threshold has been reached but it is reached before CANBUS has switched off once I'm in the house.
Is the leaving home function works every time you unlock the car? (when it's dark enough)fleagal wrote: Wed Mar 17, 2021 3:59 pmThat looks like the one I have.EdenBanim wrote: Tue Mar 16, 2021 11:27 am Saw a lot of posts about using this switch: https://www.aliexpress.com/item/1005001 ... piIRo&mp=1 on the VW T5, it's the same connector as the Polo's.. Maybe it's less buggy then the Bluetooth one?
The one I have Isn't working for most of the time..
Yes, I believe so. I think it works whether it's light or dark.EdenBanim wrote: Wed Mar 17, 2021 10:48 pm Is the leaving home function works every time you unlock the car? (when it's dark enough)
