I will become the owner in the next couple of days a January 2020 registered Flash red GTI+ with winter pack and 18" Brescia alloy wheels.
Quick question about the alarm, when going on the ferry they ask you turn off the alarm. Can the movement, vibration monitoring be turned off while on the boat?
GTI+ alarm
Re: GTI+ alarm
I think you should be able to. This is what’s in the Owner’s Manual;
Temporarily switching off the interior monitoring system and anti-tow alarm
With some equipment levels, the interior monitoring and the anti-tow alarm can be switched off temporarily in the Vehicle settings menu in the Infotainment system.
Deactivating the interior monitoring and anti-tow alarm using the Infotainment system
- Switch on the ignition.
- Deactivate the interior monitoring and the anti-tow alarm in the Vehicle settings menu in the Infotainment system.
- Close all doors and the boot lid.
- Lock the vehicle using the vehicle key.
The interior monitoring and anti-towing alarm are deactivated until the next time the vehicle is locked.
We recommend deactivating the interior monitoring and anti-tow alarm in the following situations:
- If any people or animals are to remain in the vehicle interior for a short period.
- If the vehicle is to be loaded onto another vehicle.
- If the vehicle is being transported.
- If the vehicle is going to be towed with one axle off the ground.
- If the vehicle is to be parked in a two-storey garage.
- If the vehicle is to be parked in a car wash.
Re: GTI+ alarm
Thanks for your help. SRGRTD
