help me ABS Long Coding is all zeros
mahesh_parmar
Drives: Polo 6R
Post by mahesh_parmar »
I'd like to get help with my Polo, problem is ABS Long Coding is all zeros
Thursday,15,April,2021,16:51:22:00009
VCDS Version: 20.4.0.1 (x64)
www.Ross-Tech.com
VIN: WVWG13605DT073471   License Plate:
Chassis Type: 60-VW25 (6N0)
Scan: 01 03 08 09 10 15 17 19 25 44
VIN: WVWG13605DT073471   Mileage: 66810km-41513miles
17-Instruments -- Status: Malfunction 1010
25-Immobilizer -- Status: Sporadic communication error 1000
Address 01: Engine (J0000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 T    HW: 03P 906 021 T
   Component: R3 1.2l TDI   H10 9979
   Revision: 13003003    Serial number:
   Coding: 00110014030500000000
   Shop #: WSC 53985 002 1048576
   ASAM Dataset: EV_ECM12TDI03103P906021T 001012
   ROD: EV_ECM12TDI03103P906021D.rod
   VCID: 397998E3B8599B4E05-806C
5 Faults Found:
16230 - Control Module for Instrument Cluster
          U1019 00 [063] - Missing Signal for Oil Level/Temperature
          Confirmed - Not Tested Since Memory Clear
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 31
                    Mileage: 139146 km
                    Date: 2021.04.15
                    Time: 00:02:52
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 26 °C
                    Intake air temperature: 21 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 12.101 V
                    Unlearning counter according OBD: 2
                    Fuel tank fill level: 27.8 %
                    Calculated oil temperature: 27 °C
                    Sensor for engine block temperature: raw value: 26 °C
                    Outside air temperature: 26 °C
                    Fuel temperature: 25 °C
14007 - No Communication with Instrument Cluster
          U0155 00 [008] - -
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 139294 km
                    Date: 2021.04.15
                    Time: 12:46:45
                    Coolant temperature: 67 °C
                    Intake air temperature: 0 °C
                    Voltage terminal 30: 12.382 V
                    OBD Driver demand indicated torque: 0 %
                    Communication status of data bus 1: CAN Bus ON
                    Cruise Control System (CCS): status: 00000000
                    Terminal 15 status: On
                    Gear Ratio: 0
                    Sensor for engine block temperature: raw value: 67 °C
13974 - No Communication with Instrument Cluster
          U0155 00 [008] - -
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 139294 km
                    Date: 2021.04.15
                    Time: 12:46:45
                    Voltage terminal 30: 12.375 V
                    Gear Ratio: 0
15648 - Please Check Fault Codes in Instrument Cluster
          U1024 00 [008] - -
                    Fault Priority: 6
                    Fault Frequency: 2
                    Mileage: 139294 km
                    Date: 2021.04.15
                    Time: 12:46:45
                    Exh.gas temp.sen 1: 56 °C
                    Exh.gas temp.sen 3: 0 °C
                    Exh.gas temp.sen 4: 0 °C
13973 - No Communication with Instrument Cluster
          U0155 00 [008] - -
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 139294 km
                    Date: 2021.04.15
                    Time: 12:46:45
                    Voltage terminal 30: 12.367 V
                    Gear Ratio: 0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
   Part No SW: 6RF 907 379 A    HW: 6R0 907 379 AB
   Component: ABS8.2 front  H03 0001
   Revision: --------
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 02069 000 00000
   VCID: 52ABCF4F09EF4816E4-8006
4 Faults Found:
01042 - Control Module; Not Coded
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 34
                    Reset counter: 58
                    Mileage: 66661 km
                    Time Indication: 0
                    Date: 2021.04.15
                    Time: 00:36:02
                    Hex Value: 0x0005
                    Hex Value: 0x0000
                    Hex Value: 0x3213
                    Hex Value: 0x14A2
                    Hex Value: 0x00FF
                    Hex Value: 0x007F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
03306 - Coding Not Valid
            000 - - - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 3
                    Reset counter: 98
                    Mileage: 66816 km
                    Time Indication: 0
                    Date: 2021.04.15
                    Time: 11:33:17
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x1227
                    Hex Value: 0x149E
                    Hex Value: 0x00FF
                    Hex Value: 0x007F
                    Hex Value: 0x7E00
                    Hex Value: 0x0000
01317 - Control Module in Instrument Cluster (J285)
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 98
                    Mileage: 66816 km
                    Time Indication: 0
                    Date: 2021.04.15
                    Time: 12:46:45
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x12E6
                    Hex Value: 0x139D
                    Hex Value: 0x00FF
                    Hex Value: 0x007F
                    Hex Value: 0x7E00
                    Hex Value: 0x0000
01827 - Instrument Cluster (J285); Tire Diameter Implausible
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 98
                    Mileage: 55267 km
                    Time Indication: 0
                    Date: 2019.05.29
                    Time: 00:00:15
                    Hex Value: 0x0005
                    Hex Value: 0x0000
                    Hex Value: 0x1214
                    Hex Value: 0x169E
                    Hex Value: 0x00FF
                    Hex Value: 0x007F
                    Hex Value: 0x7E00
                    Hex Value: 0x0000
   Part No SW: 6R0 907 044 G    HW: 6R0 907 044 G
   Component: Climatronic   H09 0609
   Revision: V0000000
   VCID: 377D9EDB864D8D3EF3-8062
2 Faults Found:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 98
                    Mileage: 66660 km
                    Time Indication: 0
                    Date: 2021.04.15
                    Time: 21:59:59
            013 - Check DTC Memory - Intermittent
                    Fault Status: 00101101
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 98
                    Mileage: 66660 km
                    Time Indication: 0
                    Date: 2021.04.15
                    Time: 21:59:59
   Part No SW: 6RU 937 086 H    HW: 6RU 937 086
   Component: BCM IM M+4    H34 0411
   Revision: BY034001    Serial number: 3800 184132424
   Coding: 3BB82BBF28A10000003800003E2B04910000414F60040000200000000000
   Shop #: WSC 124697 483 00190
   VCID: 66C3039F9167C4B698-8032
   Subsystem 1 - Part No SW: 6R0 959 802 AL    HW: 6R0 959 802 AL  Labels: 6R0-959-802.CLB
   Component: -------------  006 5550
   Serial number: 13202576130426065019
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 AH    HW: 6R0 959 801 AH  Labels: 6R0-959-801.CLB
   Serial number: 13202579130424165311
   Coding: 010000
   Subsystem 3 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H31 0033
   Serial number: 0561433
   Coding: 020000
   Subsystem 4 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Component: J388__TSG_HL  006 5550
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Component: J389__TSG_HR  006 5550
   Coding: 020000
2 Faults Found:
01179 - Incorrect Key Programming
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 98
                    Mileage: 66816 km
                    Time Indication: 0
                    Date: 2021.04.15
                    Time: 12:22:31
00975 - Heated Rear Window (Z1)
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 3
                    Fault Frequency: 254
                    Reset counter: 98
                    Mileage: 66593 km
                    Time Indication: 0
                    Date: 2021.04.15
                    Time: 12:09:49
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361309303806
   Coding: 108001
   Shop #: WSC 00793 648 00255
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E738BFFA177BC7630-806A
1 Fault Found:
12670208 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 98
                    Mileage: 66660 km
                    Date: 2021.04.15
                    Time: 21:59:59
   Revision: --------    Serial number: 003GW00K1KX$
   Coding: 003036
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4999E823E8B90BCE95-801C
   Part No SW: 6R0 920 861 E    HW: 6R0 920 861 E
   Component: KOMBI         H04 0304
   Coding: 140A00
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
   VCID: 377D9EDB8E4D8D3EF3-8062
1 Fault Found:
9453842 - Oil Level Thermal Sensor
          B1041 35 [009] - Signal high time > maximum
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 56
                    Mileage: 66593 km
                    Date: 2021.04.15
                    Time: 11:20:57
   Part No SW: 6N0 909 901     HW: 6RU 937 086
   Component: GW-K-CAN TP20 H34 0411
   Revision: BY034001
   Coding: 002300
   VCID: 70EF65C7A3A31A06F2-8024
2 Faults Found:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 98
                    Time Indication: 0
00474 - Control Module for Immobilizer
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 98
                    Mileage: 66660 km
                    Time Indication: 0
                    Date: 2021.04.15
                    Time: 21:59:59
   Component: IMMO          H04 0304
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADB77AF8D7FE0D6BC-803E
Address 44: Steering Assist (J792)       Labels:* 6Rx-909-144-V1.clb
   Part No SW: 6RF 909 144 J    HW: 6RF 909 144 J
   Component: EPS_ECU       H28 0401
   Coding: 0000
   ASAM Dataset: EV_SteerAssisUDSNSK 005005
   ROD: EV_SteerAssisUDSNSK.rod
   VCID: 53A5CA4B3AF5411EEF-8006
1 Fault Found:
0101 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 98
                    Mileage: 66660 km
                    Date: 2021.04.15
                    Time: 21:59:59
                    Voltage terminal 15: 11.871 V
                    Voltage terminal 30: 12.513 V
                    Status: Wait
End-------------------------(Elapsed Time: 02:12)--------------------------
Re: help me ABS Long Coding is all zeros
So first question, why is the coding all zeros? Did you change the instrument cluster? If so, did you put back the original instrument cluster?
mahesh_parmar
Drives: Polo 6R
Yes I have changed cluster just for test and I put original after I lost abs code how too fix this problem thanks
did you ever make a scan of this car before? have a look in your c:\ross-tech\vcds\logs folder to see if anything is there.
mahesh_parmar
Drives: Polo 6R
Never scan can you help me how to fix coding
Go to dealer
