A/C working good but 1 fault
Mocro
Drives: Polo 6C 1.4TDI 105HP
Post by Mocro »
Hi All,
When I bought my car at the beginning the A/C was out of gas, the reason was because the condenser was stuck so i replace it.
Everything is working fine, but when i check on VCDS I see 1 fault. When I delete the fault, it will NOT coming back also when i turn on the A/C and turn it on and of.
Also when i switch it to windows or foot or middle console (By the way I have Climate controle).
When I drive a few miles the fault will come back but I dont know the reason.Can anybody help?
                Adres 08: Airco/Verwarming       Labels: 6C0-907-044.clb
Regelapparaat Onderd.nr.: 6C0 907 044 B    HW: 6C0 907 044 B
  Component en/of Versie: Climatronic   H02 0202
       Software Codering: 201000001011200201
            Dealernummer: WSC 00788 648 00255
              ASAM Dataset: EV_ACClimaValeoPQ26 003001 (VW26)
                       ROD: EV_ACClimaValeoPQ26.rod
                      VCID: 23455A8B2AD5F157A4-8076
1 Fout Gevonden:
1048834 - Functional Limitation due to Energy Management
          B10CD 00 [008] -  -
                    Fault Status: 00000001
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 135207 km
                    Date: 2021.04.24
                    Time: 08:53:15
                    Spanning contact 30: 14.6 V
                    Extra air heating: position-release for extra-airheatingfunction: no_enabling
                    Extra air heating: position-true value: 0
                    Extra air heating: position-prescribed  value: 3
                    Extra air heating: position-prescribed  value scheme: 0
Mocro
Re: A/C working good but 1 fault
Post by Mocro »
I reset the code and then make a full scan, I forget to make the full scan before I was restting it, the language is dutch
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 10 14 15 17 19 44 5F 69
Chassisnummer: WVWZZZ6RZGY099627   KM-stand: 136062km
01-Motor -- Status: OK 0000
03-ABS Remmen -- Status: OK 0000
08-Airco/Verwarming -- Status: OK 0000
10-Park/Stuurassist -- Status: OK 0000
14-Wieldemping -- Status: OK 0000
17-Instrumenten -- Status: OK 0000
44-Stuur Hulp -- Status: OK 0000
5F-Info Electr. -- Status: Functioneert niet 0010
69-Aanhanger -- Status: OK 0000
Adres 01: Motor (J623-CUTA)       Labels: Geen
   Onderdeelnr. SW: 04B 997 027 J    HW: 04B 907 445
   Component: R3 1.4l TDI   H08 9439
   Revisie: 21006001
   Codering: 01114032423401080000
   Dealer #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM14TDI03004B997027J 004003
   ROD: EV_ECM14TDI03004B997027G.rod
   VCID: 326BAFCF652F68DF5F-8066
Geen foutcodes gevonden.
Gereedheid: N/A
Adres 03: ABS Remmen (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Onderdeelnr. SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serienummer: 08505322150909
   Codering: 21DD48858B2C33C9091A306B00588412D1CC900C0007C9098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 377D9EDB8E4D8DF768-8062
Adres 08: Airco/Verwarming (J255)       Labels:| 6C0-907-044.clb
   Onderdeelnr. SW: 6C0 907 044 B    HW: 6C0 907 044 B
   Component: Climatronic   H02 0202
   Serienummer:  1509021A-0931
Adres 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Onderdeelnr. SW: 6C0 937 089 D    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H08 0094
   Serienummer: 001588012482
   Codering: 0012085042530AFB4F844000402F07D800005B0253010000000000000000
   Dealer #: WSC 12345 123 12345
   ASAM Dataset: EV_BCMA0 006002
   ROD: EV_BCMA0_006_VW26.rod
   VCID: 3169A0C3602953C726-8064
   Sensor voor regen- en lichtherkenning:
   Subsysteem 1 - Onderdeelnr. SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serienummer: S4Y15M09D11H01M15S51
   Codering: 9038DD
   Portierregelapparaat bestuurderszijde:
   Subsysteem 2 - Onderdeelnr. SW: 6R0 959 801 CE    HW: 6R0 959 801 CE  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 9612
   Serienummer: KU0KU016091552594078
   Codering: 0400A1
   Portierregelapparaat bijrijderszijde:
   Subsysteem 3 - Onderdeelnr. SW: 6R0 959 802 CJ    HW: 6R0 959 802 CJ  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 9612
   Serienummer: KU0KU008091552510560
   Codering: 1400A1
   Regelapparaat voor schuifdak:
   Subsysteem 4 - Onderdeelnr. SW: 6R0 959 591 D    HW: 6R0 959 591 D
   Component: J245 PS72.403  H03 0004
   Serienummer: 0000FST000HNTQN00000
   Codering: 181001
   Sensor luchtvochtigheid: binnen:
   Portierregelapparaat achter: bestuurderszijde:
   Subsysteem 6 - Onderdeelnr. SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8611
   Serienummer: KU0KU010091552533482
   Codering: 0400A0
   Portierregelapparaat achter: bijrijderszijde:
   Subsysteem 7 - Onderdeelnr. SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8611
   Serienummer: KU0KU014091552571924
   Codering: 1400A0
Adres 10: Park/Stuurassist (J791)       Labels:| 5Q0-919-294.clb
   Onderdeelnr. SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revisie: --------    Serienummer: 39391525300172
   Codering: 0031351101
   ASAM Dataset: EV_EPHVA18AU3700000 002024
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 3D718CF3AC71A7A7B2-8068
Adres 14: Wieldemping (J250)       Labels: 6C0-907-359.clb
   Onderdeelnr. SW: 6C0 907 359     HW: 6C0 907 359
   Component: DAEMPFUNGS-SG H04 0007
   Serienummer: 10091502000084
   Codering: 80
   ASAM Dataset: EV_SwitcDampeContiTemic 001004
   ROD: EV_SwitcDampeContiTemic.rod
   VCID: 6ADB77AF8D7FE01F27-803E
Adres 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Onderdeelnr. SW: 6C0 959 655 F    HW: 6C0 959 655 F
   Component: VW20Airbag00P 001 0360
   Revisie: --------    Serienummer: 003RJ0055RSS
   Codering: 88CCC000000000005C0000CA000800000000
   ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 366393DF894774FF73-8062
   Ongevalsensor voor zij-airbag: bestuurderszijde:
   Subsysteem 1 - Onderdeelnr. SW: -----------    HW: 410 821 209 15
   Component: SideSensor_Df  151 0800
   Serienummer: 3575H00A11D1690141B9
   Codering: 2D2D2D
   Ongevalsensor voor zij-airbag: bijrijderszijde:
   Subsysteem 2 - Onderdeelnr. SW: -----------    HW: 410 821 209 15
   Component: SideSensor_Pf  151 0800
   Serienummer: 3585H00B91D5010233AA
   Codering: 2D2D2D
   Ongevalsensor voor zij-airbag achterin: bestuurderszijde:
   Subsysteem 3 - Onderdeelnr. SW: -----------    HW: 442 150 109 15
   Component: SideSensor_Dr  1CA 0148
   Serienummer: 3517A00B91C4E1E2E35U
   Codering: 2D2D2D
   Ongevalsensor voor zij-airbag achterin: bijrijderszijde:
   Subsysteem 4 - Onderdeelnr. SW: -----------    HW: 442 152 808 15
   Component: SideSensor_Pr  1CA 0148
   Serienummer: 3527A00B91C3DED4345X
   Codering: 2D2D2D
Adres 17: Instrumenten (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Onderdeelnr. SW: 6C0 920 741 C    HW: 6C0 920 741 C
   Component: KOMBI         201 1420
   Codering: 07250900318000080D087A001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009046
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
Adres 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Onderdeelnr. SW: 6C0 909 901 A    HW: 6C0 937 089
   Component: GW MQB A0     H08 0094
   Revisie: --------    Serienummer: 001588012482
   Codering: 030100344F0A590071000000800000010001010000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_VW26.rod
   VCID: 2643439F59E7047FC3-8072
   Regelapparaat voor multifunctiestuurwiel:
   Subsysteem 1 - Onderdeelnr. SW: 6C0 959 442 A    HW: 6C0 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H04 0019
   Serienummer: 2531507341700601AD1B
   Codering: 280000
   Regelapparaat voor accubewaking:
   Subsysteem 2 - Onderdeelnr. SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serienummer: 62262M18192821707121
Adres 44: Stuur Hulp (J792)       Labels:| 6Rx-909-144-V2.clb
   Onderdeelnr. SW: 6C1 909 144 AG    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3232
   Serienummer: PF9R0101
   Codering: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 6DD17CB3BC91F72742-8038
Adres 5F: Info Electr. (J794)       Labels:| 5G0-035-MIB-STD2.clb
   Onderdeelnr. SW: 3Q0 035 846     HW: 3Q0 035 846
   Component: MU-S-N-ER     H24 0252
   Serienummer: VWZAZ2R0492223
   Codering: 02620001BE00000051110001000808031F0300D401200100CF
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 6ED37BBFB1970C3F7B-803A
   Weergave- en bedieningseenheid 1 informatie-elektronica:
   Subsysteem 1 - Onderdeelnr. SW: 6C0 919 603 A    HW: 6C0 919 603 A
   Component: ABTm_Std2_Nav  H53 1031
   Serienummer: VWZ8Z9SKX02DCA
   Sticker met gegevens:
   Subsysteem 2 - Onderdeelnr. SW: 5NA 919 866 AG    HW: -----------
   Component: ECE AS 2020  --- 1310
   Serienummer: --------------------
1 Fout Gevonden:
1556 - Regelapparaat defect
          B2000 87 [009] - Geen boodschap
          Bevestigd - Getest sinds Wissen Geheugen
             Freeze frame:
                    Fout Status: 00000001
                    Fout Prioriteit: 6
                    Fout Frequentie: 1
                    Reset Teller: 153
                    KM-stand: 136062 km
                    Datum: 2021.05.06
                    Tijd: 16:13:31
                    Spanning contact 30: 11.9 V
                    System_Software_Error-SW_Status_Consistency: 04 01 01
                    System_Software_Error-SW_Status_Device: o
Adres 69: Aanhanger (J345)       Labels:| 5Q0-907-383.clb
   Onderdeelnr. SW: 6C0 907 383 F    HW: 6C0 907 383 B
   Component: Anhaenger     H21 0203
   Revisie: 8D001003    Serienummer: 0375570934
   Codering: 0100000202000000
   ASAM Dataset: EV_TrailFunctGener2Hella 001008
   ROD: EV_TrailFunctGener2Hella_VW26.rod
   VCID: 2D51BCB37C11372702-8078
Einde----------------------(Tijd verstreken: 02:46)------------------------
How is your battery?
Mocro
Post by Mocro »
Good, 14.15 V or something, how do i know the battery is good?
Have a look at the age of the battery. Usually they will last 4 years, anything more is a gift.
Mocro
Post by Mocro »
The battery is from factory, from 10/2015.
difficult to say. might be that the battery is unable to support the demand of the auxillary heater of the tdi, and energy management is intervening. or something is completely different. hard to say.
Mocro
Post by Mocro »
Yes that is possible, right know I didn't get the fault code and drove it everydat since the post. it seems like when its could outside and start it.
