Kufatec heated seat retrofit
Maza13
Drives: 9n polo GT tdi pd 130
Post by Maza13 »
Hello everyone,
I've recently purchased a pair of gti heated seats to fit into my 9n polo GT tdi and am having problems retrofitting them in. I followed the kufatec fitting instructions, and have now run into the issue where one seat will only heat up slightly (passenger side) and one will be permanently heated even with the switch in the off position. Ive attempted coding with a vag com and still no luck.
Any one had similar problems or have any idea?
Thanks in advance!
Re: Kufatec heated seat retrofit
Did you buy a Kufatec retro fitting harness and if so, does it come with fitting instruction that you are allowed to download after completing your buying, also are these wiring kits available in RHD form, or do you need to guess your way around translating from supplied LHD kit to RHD use?
