spark plugs for BlueGT 2013 140cv
Egt
Drives: Polo BGT
Post by Egt »
Good morning everyone, I have to change the spark plugs to my 2013 Polo BlueGT with 43000km and in the web spares I see several spark plugs with different prices and they all indicate that they are for the TSI 1.4 140cv. I have some confusion with this matter, ¿ Has anyone experience in changing the correct spark plugs for the BlueGT? I think they should be these but I am not sure of being right ...
OEM plus are 04E905612
https://www.autodoc.es/ngk/14761348 or https://www.autodoc.es/bosch/13782783
Re: spark plugs for BlueGT 2013 140cv
I'd look on the NGK website and accept what they list is correct, or if you are really really concerned, remove a plug and check which type it is either by the VAG P/N stamped on the circular section, or if not VAG part, by what is written on the plug.
NGK has always worked for me in VW Group cars and is factory fit supplier.
Egt
Drives: Polo BGT
Post by Egt »
Hello,
NGK: PZKER7A8EGS
Bosch: 0 241 145 515
Thanks ORIOn.
