Piston ring gaps
Jake_red6n2
- Drives: 6n2
Piston ring gaps
Hi guys, I’m currently rebuilding an avy and I’m stuck for piston rings gaps. I don’t want to go of the old ones in case they are worn. I ordered standard size and they have come with a smaller gap when placed into the bore. If anybody has the standard ring gaps I would be more than over the moon if you could share the secrets.
Re: Piston ring gaps
file them down?
You will have to find the specs for them for your engine, and you will need feeler gauges
