Golf 7 problem with auto lights
Miraclem
Drives: Polo 2.0tdi
Post by Miraclem »
Hello guys,
I have VW Golf 7 2.0tdi with bi-xenon headlights and auto function on my lever.
I want to know, is there any option, when the car is running on sunny day and my DRL's are ON, rear lights are ON too, but i want to be only from DRL's ON ?
When its sunny day DRL's front/rear and interior lights are ON. I want on sunny day DRL's to be ON only on front and when the night come, to switch the lights in interior, back lights and headlights ON.
Is there any codding for this ? I already have VCDS.
Also, CH/LH function doesn't work on me.. I don't know the codding in my centr.elect 9. Can someone help me with tips and codes to do it ?
Sorry, that is not a POLO, but i think they are one family.
Thank you.
CarbonChaos
Re: Golf 7 problem with auto lights
Post by CarbonChaos »
If your ok using VCDS then you could try looking in control unit 09 central electrics and look to see if Scandinavian DRL’s are turned on ? If so turn them off and see if that gets you what you want.this may be in German txt so google is your friend here.
Please back up your data before making any changes so you can go back to it easily if required
CH / LH is this function turned on in the infotainment screen ?
