Polo GT TSI 6R IND 2018 (Panda)
PandaGTTSI
Drives: 6R 1.2 TSI MY2018
Post by PandaGTTSI »
Hello there!
I own a Polo GT TSI (6R IND) model which is run a little less since I have an office car as well.
I plan to add some convenience and comfort features to my car and am greatly inspired by the mods done by the forum members.
I look forward to all of yours' support in entrancing my Polo.
Re: Polo GT TSI 6R IND 2018 (Panda)
Welcome
PandaGTTSI
[/quote]
iichel wrote: Mon Jul 26, 2021 9:16 pmWelcome
Thank you @iichel. I'm a big fan of your and @ciclo's work
PandaGTTSI
I recently tried to enable 4k OPS on my car with stock sensors as VW had stopped supplying the OPS feature.
I bought the module 6R0919475 from ebay and a CANBUS extension Harness.
I added the CAN connection by:
HIGH (T16/6 to T32/28) Orange Black
LOW (T16/15 to T32/T29) Orange Brown
The T16/6 was occupied by a Blue-Black wire which was isolated with a sleeve.
Good news is that the parking sensor all buzz and there is no loss in original Function.
Bad news is that despite all the effort and arranging the right parts, there is no OPS display on the RCD340. The RVC display comes but I don't have an option to switch to OPS display.
I checked VCDS and OPS display is already enabled. Not sure what's wrong.
I am adding the VCDS scan below:
Sunday,25,July,2021,18:06:55:63209
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
Data version: 20210226 DS325.0
VIN: MEXB18602JT124242   License Plate: 9646
Mileage: 27900km-17336mi   Repair Order:
Chassis Type: 60-VW25 (6RU)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56
VIN: MEXB18602JT124242   Mileage: 27900km-17336miles
10-Park/Steer Assist -- Status: Not registered 0011
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 KC    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 6270
   Revision: --H10---    Serial number:
   Coding: 00250056232400080000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
   ROD: EV_ECM12TFS021_VW25.rod
   VCID: 6D9215BBBC6717E318-8038
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 041 D    HW: 0AM 927 769 F
   Component: GSG DQ200G2_PQ  050 2602
   Revision: 00005008    Serial number: CU501711257141
   Coding: 0000020
   Shop #: WSC 01357 011 00200
   VCID: 2A18DEA78509C0DBBD-807E
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6R0 907 379 CB    HW: 6R0 907 379 AS
   Serial number: --------------
   Coding: 62DD2463422503C44616246D4253C0800908
   VCID: 004C5C0F9BF5EA8BC3-8054
Address 04: Steering Angle (G085)       Labels:* 6R0-959-654.clb
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 29111713470012
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EB022F7E1019C7BB1-802A
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 41CA990BD87F23838C-8014
Address 09: Cent. Elect. (J519)       Labels:. 6R0-937-08x-09.clb
   Part No SW: 6RU 937 087 R    HW: 6RU 937 087 R
   Component: BCM IM H+4    H42 0452
   Revision: BZ042001    Serial number: 6800 028180049
   Coding: 3BB02BFF08A10000013800007E2B169000C0600F608E0100220000000A00
   Shop #: WSC 13059 002 104857
   VCID: 71AA09CBA85FF3033C-8024
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 141117 04  47  0106
   Coding: 0368DD
   Subsystem 2 - Part No SW: 6R0 959 802 EF    HW: 6R0 959 802 EF  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  023 2551
   Serial number: 13102848171205181155
   Subsystem 3 - Part No SW: 6R0 959 801 ED    HW: 6R0 959 801 ED  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  023 2551
   Serial number: 13102849171129100306
   Subsystem 4 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Component: E221__MFL-TAT  H06 0023
   Serial number: 3321718080901756AB2B
   Coding: 240000
   Subsystem 5 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  022 1552
   Serial number: 13102728171204111732
   Subsystem 6 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  022 1552
   Serial number: 13102729171205093237
1 Fault Found:
01758 - Bulbs for Brake Lamps
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 25
                    Time Indication: 0
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475     HW: 6R0 919 475
   Component: PARKHILFE 4K  H07 0008
   Revision: --------    Serial number: 71391023862614
   Coding: 100001
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_VW250ParkiAssis2 S01006
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 7BB62BE3F213895396-802E
1 Fault Found:
12583168 - Powertrain Databus
          U0001 00 [008] - Unspecified Malfunction
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 54
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 6R0 959 655 J    HW: 6R0 959 655 J
   Revision: --------    Serial number: 003GW01D6F33
   Coding: 003036
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 49DA812BE84FEBC354-801C
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 6RF 920 861 D    HW: 6RF 920 861 D
   Component: KOMBI         H02 5006
   Coding: 1108000000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   VCID: 4CD4B83FE73DFEEB6F-8018
Address 19: CAN Gateway (J533)       Labels: None
   Part No SW: 6RU 909 901     HW: 6RU 937 087 R
   Component: GW-K-CAN TP20 H42 0452
   Revision: BZ042001
   Coding: 002300
   VCID: 197A116B106F5B4324-804C
1 Fault Found:
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 27907 km
                    Time Indication: 0
                    Date: 2021.07.25
                    Time: 00:00:03
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H02 5006
   Serial number:
   VCID: 6A981EA78D8900DB7D-803E
Address 44: Steering Assist (J500)       Labels:| 1Sx-909-144-44.clb
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_014_VW25.rod
   VCID: 41CA990BD07F23838C-8014
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 6RF 035 187 C    HW: 6RF 035 187 C
   Component: Radio         557 5516
   Revision: --------    Serial number: VWZ7Z2S1102383
   Coding: 0E00044000000F
   VCID: 49DA812BE04FEBC354-801C
1 Fault Found:
00856 - Radio Antenna
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 217
                    Mileage: 27025 km
                    Time Indication: 0
                    Date: 2021.06.20
                    Time: 05:27:23
End----------(Elapsed Time: 01:18, VBatt start/end: 13.6V/13.7V)-----------
Request someone to help me with the correct coding and to also help resolve the other error codes.
Gateway -> installation list -> check 10
Have a look at the adaptations for the ops module and coding for the radio.
PandaGTTSI
Thank you Iichel! I'll check the installation list again and check 10.
Unfortunately my VCDS cable broke :cry: and I have to visit a friend d to get changes done. Would you happen to have the correct coding that I can use?
Also, do you think that the Brake lamp fault is also related to this?
Coding is specific per module part number, I don't know the codes for this OPS and radio. The brake light issue is marked as intermittent, so perhaps it's not even active.
PandaGTTSI
Okay, thank you Iichel!
I'll first check the gateway and then re-check the adaptations. Al though, I think the adaptations were correct unless I've tried to activate something that can't be activated but then Coding would've not been accepted? :?
There might be a channel for reverse display, and it can be OPS, camera or automatic. Can you please show what your radio displays, in reverse gear?
patil
Post by patil »
Hello panda gt tsi
As iichel suggested, you must register your new ops module by enabling address 10 in gateway installation list.
The adaptation channel " Visual display for park assist".. set it to " automatic" in new ops module.
Post the result,
Good luck👍
Have you installed after market tail lights?
PandaGTTSI
iichel wrote: Thu Jul 29, 2021 10:05 am There might be a channel for reverse display, and it can be OPS, camera or automatic. Can you please show what your radio displays, in reverse gear?
Thank you, I will activate address 10 in the gateway and confirm. I have the RCD340 and display shown is the standard reverse camera interface. I don't get the button to switch to OPS display. I forgot to click a picture, will share it with you tomorrow.
patil wrote: Thu Jul 29, 2021 12:51 pm Hello panda gt tsi
Post the result,
Good luck👍
Hello Patil, you have have done wonderful mods, I am glad to met you here. Read all about your car.
Thanks for confirming the gateway activation. I will borrow a VCDS and do this on the weekend. Hopefully these errors won't cause a problem till then.
I have not installed aftermarket lights but I did update them to the latest design of Tail Lamps being sold right now (GTI style). I did it the OE way and changed the connector to the new type and then installed so there should not be a problem with that but surprisingly still got this error.
PandaGTTSI
Do, I've been away for a bit. I managed to fix the OPS issue and everything works great.
I'm planning the below mods soon:
1) MFSW with Paddle Shifters (I will keep the stock look)
2) Flip badge RVC since the one on the number plate is not usable during rains
3) Light in Boot
4) 12V socket in Boot
5) Light in Glove box
6) Addition of USB points in one of the blacks near the Hazard light switch
7) OEM WRMs for auto fold and unfold along with heated ORVMs
Request your guidance for points 3 to 7 along with the correct part numbers and wiring.
I look forward to learning more from all of you knowledgeable members.
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
PandaGTTSI wrote: Sun Dec 26, 2021 8:45 pm 3) Light in Boot
6L0947415 or 7L0947415
PandaGTTSI wrote: Sun Dec 26, 2021 8:45 pm 4) 12V socket in Boot
Following are from center console. So this would be easily available.
Socket
1J0919309 or 1K0919309 or 1J0919309B
Illumination Ring
1J0919341A or 6K0919341
If illumination Ring then bulb
N 0177512
Hinged Cover
1K0919341F or 1K0919341F 9B9
Flat Connector
1J0973119
PandaGTTSI wrote: Sun Dec 26, 2021 8:45 pm 5) Light in Glove box
I don't know mechanism but you can use 7L0947415 or 6L0947415
patil
Post by patil »
Hi PandaGTTSI
Here are my recommendations/ Suggestions for your new pipeline mods.
3) Light in Boot:
1x 7L6-947-101-A (trunk light assembly, including one incandescent bulb)
1x 1J0-971-972 (2 pin connector)
1x 000-979-019 (repair wire)
wiring:
+ from front dome light/footwell light wire(t73a/65)
- from tailgate lock switch ground wire (t73a/31)
4) 12V socket in Boot:
You need this kit for easy plug and play installation. https://www.ebay.com/itm/Car-Cigarette- ... 632-2357-0
Remember, this wiring harness has maximum length of 1.25m, which isn't enough to route it into the boot from front 12v socket. You must lengthen this wiring by adding additional 3m of wires (1.5mm2 thickness) inbetween to make it approx 4-4.5m long.
You also need this oem 12v outlet cover: 1K0919341F9B9
Eg: viewtopic.php?p=579180#p579180
5) Light in Glove box:
viewtopic.php?p=467245#p467245
wiring:
- from any nearby ground point.
courtesy: Master Ciclo
6) Addition of USB points in one of the blacks near the Hazard light switch:
Why this? Personally I feel it spoils the neat central console layout and would look out of place. I think you should contact 3D printing expert like Amir(Benzikopf) for this.
viewtopic.php?p=565787#p565787
viewtopic.php?p=565366#p565366
Good luck😉
PandaGTTSI
Hi @ag29 @patil
Thank you so much for getting back to me so quickly!
Just wanted to understand small points since I'm not very experienced.
1) For the light, I've already gotten the light assembly, the connector mentioned is to go into the light. For the other end where I take the power from, T73 means BCM right? Can I take the + from the Dome light by creating a Y-split cable and the - from the boot stitch T4/2? Any benefit of taking from BCM? Also, I don't want to splice any wire so what all connectors should I buy?
2) Thank you for the ebay link, I bought the same and will extend the wire as suggested. Any recommended wire that I should use? Please share an Amazon link if available.
3) I'm thinking that light for the boot and the glove Box can use the same connecting. Will that be correct?
4) I want to add the USB port I have my phone mount with wireless charging cable. Right now the wire goes from the 12V socket and looks bad. With the new USB Socket, I could use a smaller wire which will mostly hide behind the phone mount
(I keep the phone mount there as the AC vent keeps the phone cool during summers). I thought about adding an OEM Qi wireless mat but there's no space. I was thinking of I add a USB, the power supply can be taken from the 12V socket itself and I'll mount it behind the infotainment
5) Your installation guide is great and the coding is also shared so that will be of great help. I've been unable to find the right WRMs at a decent price. I also looked for the Heated ORVMs but not sure if the parts on Boodmo are correct. If you have a link from where I can purchase these I'll be grateful! :)
6) I also got the Oznium LED Lamps like graaja from Teambhp. I'm thinking that I'll install them using the footwell extension Lamp harness that people use to add Footwell Lights for the rear.
In open to any other great ideas that all of you have and for any help that you can extend with regard to parts and creating the harness.
I've seen Benzikopf's threads and that's a great idea if he can 3D Print me a small black for the USB.
I look forward to impending these soon. Thank you!
