Cruise control but no speed limiter?
Posted: Fri Jul 30, 2021 5:52 pm
by ls97
I recently bought a used 2017 Polo 1.0L (110bhp) R-Line 5 door. Been playing around with the various options and I was surprised to find that it seemingly has cruise control but no speed limiter function!
The cruise control definitely works fine using the controls on the steering wheel. But there's nothing in the options or any button I can find that would active the speed limiter. I couldn't find anything in the manual either (edition November 2016). It seems super weird to me, and a bummer as I would love to be able to use the speed limiter in trafficked, camera-ridden London.
Here's a picture of the wheel and stalk:
Can anyone confirm whether my suspicions are correct? And if so, is it possible to get the speed limiter retro-fitted somehow?
Re: Cruise control but no speed limiter?
Posted: Fri Jul 30, 2021 6:28 pm
by iichel
Yes you are correct. I think you need a set of buttons with a mode button, but I'm unsure whether that's all that there is to it.
Posted: Mon Aug 02, 2021 11:33 am
by spacewalker
check if you can code that in ECU
Posted: Wed Aug 11, 2021 12:59 pm
by rbz5416
Not sure what you mean by a speed limiter that's different to the speed set by the cruise control? In town driving I just set the cruise to whatever the speed limit is.
But you may be able to set a speed warning for winter tyres. Mine is set to 75, just as a reminder I'm drifting over the NSL. That brings up a ping & message in the display. Only pings once as you pass it, so not going off constantly. Not sure what the range of that setting is but maybe some help.
Posted: Wed Aug 11, 2021 8:19 pm
by ls97
rbz5416, a speed limiter is different from cruise control in that it sets a maximum speed over which the throttle cuts off, it doesn't attempt to maintain that speed.
Thanks all for the suggestions, trying to see if my dealer will do anything as speed limiter was included in the specs when I bought the car.
