Problem solved
Polobear6r
- Drives: Polo
Problem solved
Issue is resolved
Re: Still lambda issue after new catalytic converter
https://www.gerritspeek.nl/vag-com_dtc-16518.htmlMogelijke oorzaken:
Kortsluiting in de referentiespanning van de lambda-sensor
Lambda-sensor vervuild of defect
It's not really unsafe to drive with, but you'll probably miss a few horses and use some more fuel in the process.
Polobear6r
- Drives: Polo
Issue is resolved
Seems that the heater coil inside of lambda sensor is kaput.
What brand of lambda sensors dis you put on your car?
Polobear6r
- Drives: Polo
Issue is resolved
Bank 1 sensor 1 is the sensor upstream of the catalytic converter. Bank 1 sensor 2 is the one downstream of the catalytic converter.
Maybe try with NGK or Bosch ?
CarbonChaos
At that price 6 months is good going ,only use OEM or OEM makers sensors,others work ok for a limited time only
NTK is the brand name for NGK sensors and tends to be what VW Group fit at engine plants and sell as spares.
Maybe things have changed over the past 10>15 years, but when I checked back then, I found that buying locally from a VW dealership was very close in price to buying an NTK same part online and getting it delivered.
Thats a really useful information.
With sensors, buy cheap pay it twice.
