Hi again guys. I have a polo gti 9n3 2007
I used to have some issues with the esp and the electronics of steering wheel. I found a probably not a problem with the rear alarm bulb. And now there it goes again. Fuse No 7 blows all the time. I have no power steering esp is off and the sensor of oil blinking yellow on start up.
I went to an electrician but we can not find something wrong. The power steering motor works well the abs sensors are ok.
Please give some ideas to check. Thanks
Esp ghost
Pologti20vt
- Drives: Polo gti 9n3
CarbonChaos
Re: Esp ghost
You will need to study the wiring diagram and see what else is on that circuit for fuse 7 .
Then carefully check wiring for damage and eliminate all consumers on that fused circuit.
There is no quick fix for a short circuit,but a good electrical engineer should know this anyway ?
