I have recently installed LED bulbs into the cornering lights which is a great improvement over the stock H8 35w halogen bulbs
Now I can actually see them working I’ve increased the upper speed threshold , decreased the steering wheel angle. At greater speed you use less steering angle input .
But I’m puzzled by this one line in the adaptation screen
Can anyone explain the ‘ steering wheel angle offset -63.50 degrees
Even by decreasing the lower steering wheel angle from 120 (stock)to 75 degrees in makes little difference
Cornering light coding?
CarbonChaos
CarbonChaos
Re: Cornering light coding?
Anyone?
I'd suggest to contact OBD-eleven themselves. I have no clue what it's about.
giannis20vt
hi, did you find the solution you were looking for ?
