Cornering light coding?
Posted: Sat Oct 09, 2021 11:42 pm
by CarbonChaos
I have recently installed LED bulbs into the cornering lights which is a great improvement over the stock H8 35w halogen bulbs
Now I can actually see them working I’ve increased the upper speed threshold , decreased the steering wheel angle. At greater speed you use less steering angle input .
But I’m puzzled by this one line in the adaptation screen
Can anyone explain the ‘ steering wheel angle offset -63.50 degrees
Even by decreasing the lower steering wheel angle from 120 (stock)to 75 degrees in makes little difference
Re: Cornering light coding?
Posted: Tue Dec 28, 2021 12:35 pm
by CarbonChaos
Anyone?
Posted: Tue Dec 28, 2021 1:34 pm
by iichel
I'd suggest to contact OBD-eleven themselves. I have no clue what it's about.
Posted: Wed Jan 04, 2023 6:18 pm
by giannis20vt
hi, did you find the solution you were looking for ?
