Handbrake Warning light flashing and beeping
ChrisR1995
Drives: 53 plate
Post by ChrisR1995 »
Hi guys, I’m new around here and I’m just looking to see if anyone has had the same problem.
I’ve got a 53 plate Polo and yesterday it started flashing the handbrake sign on the dash and making a beep. It did it only a few times at first but now it’s every time I even slightly turn right or even just at random times.
I’ve checked my brake fluid and it’s fine and the brakes seem okay, I recently changed two ignition coils but that isn’t anything to do with it (I don’t think)
Please help 😤
Re: Handbrake Warning light flashing and beeping
Have you got into round about the handbrake lever to see if the switch looks okay and its wiring looks okay - or maybe the handbrake lever is not being allowed to reach its proper "off" position?
Edit:- failing that, it might be an issue with the cabling or terminations on the instrument panel, like a cracked solder joint - though that is just a guess as I have not worked out how that circuit works and so what effect a cracked solder joint at the cable connection point would make - start at the handbrake lever area.
ChrisR1995
Drives: 53 plate
Hi mate, thanks for the reply!
Should I just take the plastic off and have a look around?
It started just when I was turning right but now it’s constant and it’s doing my head in!
Thanks again
We traded our 2002 9N Polo in 2015, so I'm a bit out of touch with how to reach into that area, but taking the centre console off will work.
ChrisR1995
Drives: 53 plate
Hi mate,
Done all that but had no luck.
I drove for a little bit with the handbrake slightly on just to see if it was a different noise and it is.
The beep I get with the handbrake light flashing is different to the one I get when I leave the handbrake on and drive.
Any other suggestions pal
CarbonChaos
Post by CarbonChaos »
So are you sure its the parking brake symbol on the dash ? not the low brake pad warning lamp or low fluid level warning lamp ?
you can post a picture if your unsure
ChrisR1995
Drives: 53 plate
I’ve also got a video but I don’t think I can attach it here.
ChrisR1995
Drives: 53 plate
CarbonChaos wrote: Tue Nov 09, 2021 12:13 pm So are you sure its the parking brake symbol on the dash ? not the low brake pad warning lamp or low fluid level warning lamp ?
CarbonChaos
Like Rum4mo suggested look at the instrument cluster wiring and connectors next
Guss2005
Drives: 2002 9n 1.2
Post by Guss2005 »
Hi! I seem to have the same problem. Right now the light is comming up only during sharp turns, but it's getting more frequent... What was couse to this problem in your case and how did you fixed it? :)
Maarten
Post by Maarten »
Did you check your brakefluidlevel?
