Hello People,
I am in the progress of upgrading my BCM from 86 to 89, i have replaced the BCM and coded then i noticed whichever is related to LIN bus is not working
such as Door controls, Steering switch etc. Cluster rewiring is still pending, is that a reason or what would be the issue..if i replace 86 back then it works fine.
Steering switch's, Door controls are not working with BCM 89 upgrade from 86
OutofOffice
Re: Steering switch's, Door controls are not working with BCM 89 upgrade from 86
impossible to say just by your post. scan please before and after.
OutofOffice
Hey Iichel,
Thanks for replying to this post. I have figured out the issue the BCM i got from the vendor was faulty after replacing another one it works finr
