1.6 tdi P0101 00 [167] - Implausible Signal
Luigid
Drives: Polo 6r 1.6 tdi
Post by Luigid »
hello guys, it's been a while since I can not get rid of this light, I also changed the mass air flow sensor + modification to the intake by vw but nothing, advice?
through vcds I can easily read the value of g / s (in idle they are between 10-11g / s)
the car has the egr off + remapping but hasn't given any problems for over 2 years without touching anything.
Thanks You!
   Address 01: Engine       Labels: 03L-906-023-CAY.clb
Control Module Part Number: 03L 906 023 E    HW: 03L 906 023 D
  Component and/or Version: 1,6l R4 CR td H13 8830
           Software Coding: 00114014002400080000
            Work Shop Code: WSC 00914 264 96370
              ASAM Dataset: EV_ECM16TDI02103L906023E 003010 (VW25)
                       ROD: EV_ECM16TDI02103L906023AH_003.rod
1 Fault Found:
7330 - Mass Air Flow Sensor (G70)
          MIL ON - Not Confirmed - Tested Since Memory Clear
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 9
                    Mileage: 72176 km
                    Date: 2069.14.07
                    Time: 16:45:59
                    Engine speed: 1472.75 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 40 km/h
                    Coolant temperature: 83 °C
                    Intake air temperature: 28 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 14.005 V
                    Sensor for temp after charge air cooler: raw value-TBA_MES: 22 °C
                    Charge air pressure: actual value-MAP_MMV: 1109.44 hPa
                    Air mass: actual value (mg/stroke)-MAF_MES: 544.791 mg/stroke
                    Air mass: specified value-MAF_SP_MMV: 529.40 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
                    Throttle_actuator_commanded_value-ANG_SP_THR[0]: 96.001 %
                    Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 84.174 %
Readiness: 1000 0000
Re: 1.6 tdi P0101 00 [167] - Implausible Signal
We had a similar issue on A3 ( CAY), we fitted two mafs and then same fault appeared. The car also had work on ECU
you should log data for (mg/stroke)-MAF_MES 3rd or 4 gear
Id try to clean the MAF with brake cleaner and spraz some contact spray id you have in the connector.
