1.6 tdi P0101 00 [167] - Implausible Signal
Posted: Sat Dec 04, 2021 6:06 pm
hello guys, it's been a while since I can not get rid of this light, I also changed the mass air flow sensor + modification to the intake by vw but nothing, advice?
through vcds I can easily read the value of g / s (in idle they are between 10-11g / s)
the car has the egr off + remapping but hasn't given any problems for over 2 years without touching anything.
Thanks You!
Thanks You!
Address 01: Engine Labels: 03L-906-023-CAY.clb
Control Module Part Number: 03L 906 023 E HW: 03L 906 023 D
Component and/or Version: 1,6l R4 CR td H13 8830
Software Coding: 00114014002400080000
Work Shop Code: WSC 00914 264 96370
ASAM Dataset: EV_ECM16TDI02103L906023E 003010 (VW25)
ROD: EV_ECM16TDI02103L906023AH_003.rod
1 Fault Found:
7330 - Mass Air Flow Sensor (G70)
MIL ON - Not Confirmed - Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 9
Mileage: 72176 km
Date: 2069.14.07
Time: 16:45:59
Engine speed: 1472.75 /min
Normed load value: 0.0 %
Vehicle speed: 40 km/h
Coolant temperature: 83 °C
Intake air temperature: 28 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.005 V
Sensor for temp after charge air cooler: raw value-TBA_MES: 22 °C
Charge air pressure: actual value-MAP_MMV: 1109.44 hPa
Air mass: actual value (mg/stroke)-MAF_MES: 544.791 mg/stroke
Air mass: specified value-MAF_SP_MMV: 529.40 mg/stroke
EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
Throttle_actuator_commanded_value-ANG_SP_THR[0]: 96.001 %
Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 84.174 %
Readiness: 1000 0000
