Hello,
I have recently had a problem with the washer fluid not working on my sisters 2011 Polo 1.2 TSI SEL.
I have already checked the fuses and replaced the washer fluid pump. That didn’t fix it, so I tested the power going to the washer pump, and there was no voltage. So I then replaced the the wiper and indicator stalks and it still hasn’t fixed it!
Any ideas on what to try next?
Thanks,
Alisdair
Washer fluid not working
CarbonChaos
Re: Washer fluid not working
recheck the fuse for the pump in the fuse box in the dash,they are not always where they say they are it depends on the model year , so make sure your looking at the correct fuse layout
I'm guessing that you checked that the rear washer did not work either?
