vw polo 9n bottle-what is it
scotspie501
Drives: 2002
Post by scotspie501 »
Does anyone know what the container on the bottom right with a screw top is
It sits down at the bottom on the right
CarbonChaos
Re: vw polo 9n bottle-what is it
Post by CarbonChaos »
Power steering fluid
If you take the cap off, you should find that the bottom of the "button" on the cap is wet, if so that means that the fluid level is okay. As far as I can remember, the fluid type/spec is written on the cap.
scotspie501
Drives: 2002
Brilliant guys
thanks for the information never even gave it a thought
as its a older car you forget things like that
as he uses it it brings back memories of having to work on older more often than new cars
