DTUK Pedalbox for VW Polo GTI 1.8TSI
militarymad
Drives: GTI 1.8TSI (6C)
Post by militarymad »
NEW & UNUSED SELL £155.00 - RETAIL £209.00
What is it?
The Pedalbox is a throttle response modification designed to optimise the characteristics of your vehicle's throttle pedal and improves the response of the engine significantly. The pedal box includes 3 different driving modes which are City, Sport & Sport Plus - Each program also has fine adjustment to get that optimised setting for every driver.
What does it do?
The Pedalbox plugs in between the sensor and control module on the top of the throttle pedal. The pedal box intercepts the signal and alters it to a different level working in the same manner as a manufacturers sport button reducing the amount of pedal travel to engage the engines full potential.
Why would you install a Pedalbox to your vehicle?
The Pedalbox is a great addition to any vehicle if you feel that your vehicle doesn't have it's full response. It allows a much better driving pleasure from day to day driving to getting the hammer down. Pulling out of a corner you may feel sometimes you're waiting for the vehicle to respond to you putting your foot down? The response is virtually instant with the pedal box installed. this is a great advantage when you need to overtake on the motorway, that instant response allows you to overtake swiftly and safely.
High-performance microprocessors with the latest DSP technology ensure a more accurate and faster signal transmission for an optimal tuning result.
The Pedalbox: Tuning for your car's accelerator
DTE Systems developed the PedalBox in order to improve response in modern cars. The PedalBox is an additional control unit, with four user-selectable programmes, that increases throttle response by removing delays in the accelerator, enhancing driveability.
GREATER CONTROL. USER-ADJUSTABLE.
All drivers face a wide range of driving conditions and situations. The PedalBox allows drivers to choose between four levels, each with three separate modes offering improved response. The PedalBox includes different programmes tailored to meet the most drivers’ range of driver's wishes. The driver can select the programme most suited to the driving situation.
REDUCED RESPONSE TIME. MORE DYNAMIC.
Moments of delay are a thing of the past. The signal is immediately followed by the response, giving the driver the feeling that he or she is accelerating faster. However, the torque remains the same. It is merely the response ratios that have improved.
MAXIMUM EFFICIENCY, GREATER DRIVING PLEASURE.
Once responsiveness has improved, driving is a lot more fun. Plus, quick acceleration without any delay gives drivers the feeling of being in better control of their vehicle.
Modifying the values set by the manufacturer therefore has advantages. The PedalBox will meet the expectations of customers and their cars. The often-delayed throttle response of modern engines is gone, while retaining the standard engine control unit.
Please see my other listings for VW Polo GTI 1.8TSI Tuning Parts
DTUK Pedal Box description.jpg (88.9 KiB) Viewed 15023 times
DTUK PEDAL BOX.jpg (38.82 KiB) Viewed 15023 times
Last bumped by militarymad on Sun Jan 23, 2022 11:47 pm.
