ABS Long code needed
semaisking
Drives: POLO 6R 1.4
Post by semaisking »
Hello guys,
i bought this cute flooded 2009 Polo 6R 1.4, everything is nearly done but the main obstacle is the problem with getting the long code for my ESP unit. Found the ESPcalculator on the web but it doesnt work for my unit.
Is there any chance to receive the darn code, so i can get rid of the major lights on my dash and get the power steering assist back?
Thanks a ton!!! :D
Saturday,08,January,2022,17:32:32:00009
VCDS Version: 21.9.0.2
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WVWZZZ6RZAY072623   License Plate:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56
VIN: WVWZZZ6RZAY072623   Mileage: 140830km-87507miles
Address 01: Engine        Labels: 03C-906-024-BXW.lbl
   Part No SW: 03C 906 024 BH    HW: 03C 906 024 BH
   Component:       CGGB  MM4HV G 8327
   Revision: --H09---    Serial number:
   Coding: 0000071
   Shop #: WSC 07102 298 177429
   VCID: 65C10493AF61CFA1D2-515A
   VINID: 9E69EAAAA1A2A91A401C21820C49610369
Readiness: 0110 0001
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 R    HW: 6R0 907 379 R
   Component: ESP8.2i front H04 0002
   Revision: --------
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 80093 222 69422
   VCID: 4D91DC3310D117E1FA-8018
3 Faults Found:
03306 - Coding Not Valid
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 9
                    Reset counter: 91
                    Mileage: 140833 km
                    Time Indication: 0
                    Date: 2016.05.31
                    Time: 04:08:11
                    Hex Value: 0x0007
                    Hex Value: 0x0000
                    Hex Value: 0x3009
                    Hex Value: 0x1492
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
01042 - Control Module; Not Coded
            000 - -
                    Fault Priority: 0
                    Fault Frequency: 29
                    Reset counter: 91
                    Mileage: 140833 km
                    Time Indication: 0
                    Date: 2016.05.31
                    Time: 02:08:04
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3011
                    Hex Value: 0x149B
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
00778 - Steering Angle Sensor (G85)
            005 - No or Incorrect Basic Setting / Adaptation
                    Fault Status: 01100101
                    Fault Priority: 0
                    Fault Frequency: 8
                    Reset counter: 91
                    Mileage: 140833 km
                    Time Indication: 0
                    Date: 2016.05.31
                    Time: 04:03:02
                    Hex Value: 0x0002
                    Hex Value: 0x0000
                    Hex Value: 0x3051
                    Hex Value: 0x1B9A
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x8000
                    Hex Value: 0x0000
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
   Part No SW: 6R0 820 045 E    HW: 6R0 820 045 E
   Component: Climatic       24 0600
   Revision: 00 10 24
   VCID: 306FA5C763235A09F1-8064
1 Fault Found:
16372 - Control Module; Unspecified Internal Error
            014 - Defective
                    Fault Status: 01101110
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 15662 km
                    Time Indication: 0
                    Date: 2011.11.02
                    Time: 09:15:52
   Part No SW: 6R0 937 087 B    HW: 6R0 937 087 B
   Component: PQ25 BCM      H08 0025
   Revision: BF008001    Serial number: 9955A149090992
   Coding: 248829E888610100003000007E0B1CC80080400F608C00002000
   Shop #: WSC 64564 324 38760
   VCID: 3C7781F7BF6BAE695D-8068
   Subsystem 1 - Part No SW: 6R0 959 801 H    HW: 6R0 959 801 H  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  004 0803
   Serial number: KU0-KU031.08.0911346
   Coding: 08BC30
   Subsystem 2 - Part No SW: 6R0 959 802 K    HW: 6R0 959 802 K  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  004 0803
   Serial number: KU0-KU021.08.0913084
   Coding: 02BC30
   Subsystem 3 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  004 0803
   Serial number: KU0-KU002.09.0912911
   Coding: 08BC32
1 Fault Found:
01333 - Door Control Module; Rear Left (J388)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 91
                    Mileage: 140833 km
                    Time Indication: 0
                    Date: 2016.05.31
                    Time: 04:42:24
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475     HW: 6R0 919 475
   Component: PARKHILFE 4K  H07 0008
   Revision: --------    Serial number: 71320924506933
   Coding: 100001
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_VW250ParkiAssis2 S01006
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 7BF542EBF2E5695114-802E
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10AirbagA09 H09 0018
   Revision: --------    Serial number: 003DW0046UCE
   Coding: 003039
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 428BFF0FD58FD89917-8016
   Serial number: 349  RB4000000000005
   Serial number: 350  RB400000000000/
7 Faults Found:
9443091 - Driver's Side Airbag Crash Sensor
          B1017 13 [137] - Open Circuit
9451027 - Crash sensor side airbag; passenger side
          B1036 13 [137] - Open Circuit
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 140833 km
                    Date: 2022.01.08
                    Time: 04:42:22
9443328 - Rear Side Airbag Crash Sensor (on driver's side)
          B1018 00 [000] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 140833 km
                    Date: 2022.01.08
                    Time: 04:42:27
0000 - ROD - Unknown Error Code
          - 00 [000]
                    Fault Priority: 1
                    Fault Frequency: 254
                    Reset counter: 0
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
          - 00 [000]
                    Fault Priority: 1
                    Reset counter: 0
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
          - 00 [000]
                    Fault Priority: 1
                    Reset counter: 0
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
          - 00 [000]
                    Fault Priority: 1
                    Reset counter: 0
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
   Part No SW: 6R0 920 860 B    HW: 6R0 920 860 B
   Component: KOMBI         H23 0112
   Coding: 140A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   VCID: 3365AACB9A3561118C-8066
1 Fault Found:
10485833 - Internal Control Module Memory Check Sum Error
          B2000 49 [137] - Internal Electronic Failure
                    Fault Priority: 2
                    Fault Frequency: 1
   Part No SW: 6N0 909 901     HW: 6R0 937 087 B
   Component: GW-K-CAN TP20 0025
   Coding: 002200
   VCID: 70EF65C7A3A31A09B1-8024
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H23 0112
   Serial number:
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10150
   Shop #: WSC 00000
   VCID: 2E53BBBFED174CF9E3-807A
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2L9134216
   Coding: 0800020002
   VCID: 65C104936C61CFA1D2-8030
1 Fault Found:
00856 - Radio Antenna
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 91
                    Mileage: 140833 km
                    Time Indication: 0
                    Date: 2016.05.31
                    Time: 04:42:37
End-------------------------(Elapsed Time: 02:23)--------------------------
Re: ABS Long code needed
does it start and run?
semaisking
Drives: POLO 6R 1.4
Of course, it runs and drives just fine, apart from steering assyst doesnt work, ABS, ESP and tyre pressure lights are on.
I understand. These ABS units are a b***h to find coding, especially in exotic combinations like 1.2 MPI engine. And I know because I did a lot of reverse engineering.
It takes a lot of time and searching to find the perfect match.
The easiest way is to do SVM at the dealership or if you have a legal vcds, go to ross tech forum.
semaisking
Drives: POLO 6R 1.4
Dang. :(
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
iichel wrote: Sun Jan 09, 2022 12:28 pm The easiest way is to do SVM at the dealership or if you have a legal vcds, go to ross tech forum.
I thought most of us are using Original/legal VCDS. If I can recollect someone (in some thread) had replied to use latest as well as original cable -- > so scan adds or deducts something to pinpoint same.
210224E3217400B4842B24E484D400401300 ... :?:
semaisking
Drives: POLO 6R 1.4
ciclo wrote: Mon Jan 10, 2022 5:12 am 210224E3217400B4842B24E484D400401300 ... :?:
It works!!!!
I cant express how happy i am. You saved me a lot of time and headaches.
If u want i can send a little gratitude tip through paypal or crypto. :D
The best thanks I can receive is that you post a new autoscan with this problem solved ... please do so, thank you !!!
I'd like to see a few more things about your 6R after ABS coding ... just curious, nothing relevant.
nice job ciclo, i'm impressed, first try success
Thanks Michel, you already know that we both have the devil on our side ... 🤭
Do you remember CNK's 6R? ... then you know.
semaisking
Drives: POLO 6R 1.4
ciclo wrote: Mon Jan 10, 2022 8:29 pm The best thanks I can receive is that you post a new autoscan with this problem solved ... please do so, thank you !!!
Yeah i will no prob, ill try and get the autoscan tomorrow night, my workshop is 25km away from my home.
It is not necessary that you go to the workshop with the sole purpose of the new autoscan, just in case you visit it again for other reasons.
It is only a personal curiosity and it will only be useful to me, so we can wait or even not necessary if you do not return for the workshop for other reasons. :wink:
ciclo wrote: Mon Jan 10, 2022 8:45 pm Thanks Michel, you already know that we both have the devil on our side ... 🤭
How can we forget about the blue wonder wagon?
semaisking
Drives: POLO 6R 1.4
ciclo wrote: Mon Jan 10, 2022 9:19 pm It is not necessary that you go to the workshop with the sole purpose of the new autoscan, just in case you visit it again for other reasons.
I got ya my man, dont worry.
