Vag-com or VCDS Codes
RS250PS
Drives: 1.0 115ps mk6
Post by RS250PS »
Hello everyone,
I own the highline polo and recently bought the Vag-Com and I started using the VCDS.
Does anyone know where can I find some codes to unlock some "hidden" features? For example, I saw a video that through VCDS you can make the right mirror tilt down when reverse is selected.
Any ideas about such codes?
Paschalis
Re: Vag-com or VCDS Codes
Generally speaking, VCDS has built in "self help" in as much when you look at channels/fields and check each "location" VCDS should give you help in interpreting what the "bits" and their two state equate to.
But I'd think with time someone will have written up an easy guide to what can be done and where to find that functional change.
So, maybe spend some time looking around in the relevant controllers and collect that information, some changes obviously require you to make changes in more than one controller to achieve a new feature.
RS250PS
Post by RS250PS »
Nice, thank you for your response! Any other ideas for cool "features" are welcome!
Remember "tilt when in reverse" will only apply to certain car configurations, not all from factory without some options or trim level.
RS250PS
Post by RS250PS »
I will keep that in mind! Thanks
