Fitting Mk4 R32 front brakes
Looking to fit R32 brakes to my Polo 6R simply to fill the 17" wheels more. Is this a straight swap or are brackets required? Already upgraded to 288mm GTI brakes in the front
Re: Fitting Mk4 R32 front brakes
I suppose the correct answer is yes. the diameter will fit, but you need to make sure your rims will have the correct offset to clear the brake calipers.
