air bag light on
scotspie501
Drives: 2002
air bag light on
Post by scotspie501 »
Hi All
I have this question before ,my airbag light is on and i,ve tried vag com -lite and can connect with engine and various others abs etc
the only one I cant connect with is airbag
does this mean the module is faulty and requires a new one and can I buy one from e-bay as I have seen them for sale
or does it need to be programmed
its driving me crazy
scotspie501
Drives: 2002
Re: air bag light on
Hi all
does anyone know the dc supplies and earth to check for the air bag module
I have a haynes manual but cant find it
even a drawing would be great
CarbonChaos
Post by CarbonChaos »
If the airbag light is on due to non communication you should get faults in other control units that you can read .
This may give you a clue if it is indeed a faulty control unit for air bag ?
Edit: it’s also a M.O.T failure
scotspie501
Drives: 2002
I dont think its a MOT failure
i,m trying to find out Dc connections for the airbag module
all other modules are good just cant connect to that module
CarbonChaos
I think your wrong there, see here as these cars don’t have the function to indicate the passenger air bag is turned off it just indicates a fault.
7.1.6. Supplementary restraint system (SRS)
The SRS MIL (Malfunction Indicator Lamp) should only be failed if it is indicating a system malfunction. A lamp illuminated to indicate the passenger airbag is disabled is not to be regarded as a defect.
Warning messages on dashboard displays are not a defect in their own right, but may assist the tester in determining that the warning lamp is illuminated because a malfunction exists.
Defect Category
(a) An SRS malfunction indicator lamp (MIL) indicates a system malfunction Major
Taken directly from the mot inspection manual
scotspie501
Drives: 2002
Thanks for the info
i,m keen to get the Dc supplies checked
cant seem to find a wiring diagram for the dc supplies
scotspie501
Drives: 2002
Re wiring diagram for airbag module
Hi All
does anyone know the dc supply for the airbag module
even a wiring diagram please
scotspie501
Drives: 2002
Re passenger air bag or whole system
Hi All
When the airbag light is on is the fault on the passenger side or the whole system
cannot communicate with Airbag ECM with vag com lite that is what me thinks its the ECM
any ideas
scotspie501
Drives: 2002
Hi All
I have tried to clear my airbag light with vag come lite but put the polo in for MOT and the garage cleared it with their Bosch system
does any know why it would clear with their system and not mine
great result from the garage
Maybe that fault clearing is not within the scope of the "lite" version, have you checked up on exactly what the "lite" version is capable of?
sim0n_parker
Drives: Transporter
Post by sim0n_parker »
If you post a year and engine etc I may be able to get a diagram and tell you the pin outs for the ecu
scotspie501
Drives: 2002
Hi All
thanks to everyone that added comment but the garage cleared it when I went to pick the car up and did not charge me
maybe to do with my vag com lite
no lights on now also cleaned the butterfly flap on the throttle body and no error codes came back
