Hi there,
Just wondering what bulbs are used in the factory fitted 2016/17 6C GTI LED unit. I can't find the type anywhere. Any links would be appreciated.
Bulbs for 6C GTI LED UNIT
kyle_frobisher18
- Drives: GTI 6C
Dink
- Drives: 2015 GTI
Re: Bulbs for 6C GTI LED UNIT
they will be a custom unit not based on any sort of "H" type lamp
Are you meaning the types of filament bulbs that are also used at the front of that car when it has LED headlights and LED DRLs?kyle_frobisher18 wrote: Wed Feb 02, 2022 3:43 pm Hi there,
kyle_frobisher18
- Drives: GTI 6C
Yes mate I mean that, if one went what bulb would I be for example the main beamRUM4MO wrote: Wed Feb 02, 2022 6:24 pmAre you meaning the types of filament bulbs that are also used at the front of that car when it has LED headlights and LED DRLs?kyle_frobisher18 wrote: Wed Feb 02, 2022 3:43 pm Hi there,
d-ash
- Drives: 6C 2016 R-Line 1.2 90PS - Blue Silk
I think you would have to replace the complete headlight unit if you currently have LED headlights. Around £500 per unit I believe
The light bulbs in the OEM LED units are a proprietary VW unit but can be replaced separately
5 and 6 are the low and high beams
