Polo 6R: Upgrade BCM Help
polobyte
Drives: 6R 1.6 TDI 105HP 2012
Post by polobyte »
Hello guys,
I bought new BCM for my Polo 6R, when I connect it to car, VCDS can’t read it. New BCM is 7E0937090C.
Do I need to do some wiring or?
polobyte
Re: Polo 6R: Upgrade BCM Help
Post by polobyte »
Anyone?
Probably... But not enough information to be sure
polobyte
Post by polobyte »
This new BCM is from Transporter 5.5.
Current BCM that is in car is 6R0937088F.
Is there anything else that you need to know?
yes you need to re-wire all of you canbus (instrument cluster, powertrain, OBD, LIN generator) to the BCM and remove the external gateway. perhaps a wire from T73b/4 to the dimmer T6/3.
polobyte
Post by polobyte »
Is there any schematics on net?
I don't know, best is to get some schematics of 088F and 7E0 BCM max for yourself and compare.
ZahariGeorgiev
Drives: Polo 6R 1.6 TDI
Post by ZahariGeorgiev »
Check if this helps you a little bit:
https://drive.google.com/file/d/1cXw67i ... 9R6DO/view
