2008 Polo Flip key conversion
POLOZ
Post by POLOZ »
Hi Guys,
Any ideas if the following 'Button' key fob with central locking
Converted to a flip key?
CarbonChaos
Re: 2008 Polo Flip key conversion
Post by CarbonChaos »
Short answer is no, not without adding additional hardware ie a after market CDL kit which would probably have its own fob for remote locking/unlocking then you would still have the factory key to start the car.
There were kits out there but expensive,I’m not sure if anyone here has retro fitted the OEM type CDL ? I believe you would need to upgrade control units etc to do so.
giannis20vt
Post by giannis20vt »
You can add a universal kit like this
https://www.ebay.com/itm/264075483072?m ... ZYQAvD_BwE
Or like this, (more "original" look)
https://www.rclick.co.uk/shop/index.php ... er=product
POLOZ
Post by POLOZ »
Thanks giannis20vt and CarbonChaos for the suggestion :)
Think I am going to leave it as is for time being. Waiting on the battery to arrive so I can check if the remote button works.
CarbonChaos
there is no remote function on the key you pictured in the first post ,only a dim light
giannis20vt
CarbonChaos wrote: Tue Feb 08, 2022 11:07 am there is no remote function on the key you pictured in the first post ,only a dim light
Exactly !!!
POLOZ
Post by POLOZ »
A 'dim' light? :roll: What you mean?
The 'VW' emblem is a button itself. There is central locking on the car, the key button is not working now as I am waiting on replacement battery.
POLOZ
Post by POLOZ »
Hopefully a better picture, you can see the key with the blue 'VW' emblem has a button in the middle compared to the other one.
My polo is a 2008 Polo Match
giannis20vt
Well, the key you have is the key with the light, there is no remote control.
POLOZ
Post by POLOZ »
giannis20vt wrote: Wed Feb 09, 2022 1:42 pm Well, the key you have is the key with the light, there is no remote control.
Wth :shock: that explains why there is no PCB board when I lifted it. Sorry for the confusion :wink:
@POLOZ, don't worry, you are not the first and will not be the last VW Group car owner to make that mistake!
Onwards and upwards.
