Hi all, newbie here. Trying to help out a non-technical friend with his beloved, stock 2016 Polo 1.4GT. At 60.000 miles, it's occasionally stalling from idle, getting worse, and I offered him to read out the error codes. I got an astonishing 66 of them falling in 3 categories: O2 sensor, Boost control pressure sensor, and assorted camshaft/timing codes. All listed below. Does this sound familiar to anyone?
Should one suspect low battery voltage or similar as the culprit for such a vast array of codes (including several "circuit failures")?
Any ideas welcome!
Thanks, Mike
DTC report
Selected brand: BAW
VIN: WVWZZZ6RZHY002867
============1==============
P0052(69)
Raw code: 005269
ECU: Engine control unit
Status: Test not completed during this operation cycle
OBDII: Heated oxygen sensor (HO2S) 1, bank 2, heater control - circuit high
============2==============
P0052(68)
Raw code: 005268
============3==============
P004F(28)
Raw code: 004F28
OBDII: Turbocharger (TC)/supercharger (SC) boost pressure control B - circuit intermittent/erratic
============4==============
P0052(64)
Raw code: 005264
============5==============
P0052(66)
Raw code: 005266
============6==============
P0052(65)
Raw code: 005265
============7==============
P004F(27)
Raw code: 004F27
============8==============
P0052(61)
Raw code: 005261
============9==============
P0052(63)
Raw code: 005263
============10==============
P0052(62)
Raw code: 005262
============11==============
P004F(26)
Raw code: 004F26
============12==============
P0052(5E)
Raw code: 00525E
============13==============
P0052(60)
Raw code: 005260
============14==============
P0052(5F)
Raw code: 00525F
============15==============
P004F(25)
Raw code: 004F25
============16==============
P0043(87)
Raw code: 004387
OBDII: Heated oxygen sensor (HO2S) 3, bank 1, heater control - circuit low
============17==============
P0041(41)
Raw code: 004141
Status: Test not completed since last DTC clear, Test not completed during this operation cycle
OBDII: Oxygen sensor signals swapped, bank 1 sensor 2/bank 2 sensor 2
============18==============
P004A(06)
Raw code: 004A06
OBDII: Turbocharger (TC)/supercharger (SC) boost pressure control B - open circuit
============19==============
P004A(04)
Raw code: 004A04
============20==============
P004A(05)
Raw code: 004A05
============21==============
P004E(B9)
Raw code: 004EB9
OBDII: Turbocharger (TC)/supercharger (SC) boost pressure control A - circuit intermittent/erratic
============22==============
P004E(B7)
Raw code: 004EB7
============23==============
P0045(FF)
Raw code: 0045FF
OBDII: Turbocharger (TC) boost control solenoid/supercharger (SC) boost control solenoid - open circuit
============24==============
P004B(66)
Raw code: 004B66
OBDII: Turbocharger (TC)/supercharger (SC) boost pressure control B - circuit range/performance
============25==============
P004B(62)
Raw code: 004B62
============26==============
P004B(69)
Raw code: 004B69
============27==============
P004A(09)
Raw code: 004A09
============28==============
P0011(02)
Raw code: 001102
OBDII: Camshaft position (CMP), intake/left/front, bank 1 - timing over-advanced/system performance
============29==============
P0011(01)
Raw code: 001101
============30==============
P0012(5D)
Raw code: 00125D
OBDII: Camshaft position (CMP), intake/left/front, bank 1 - timing over-retarded
============31==============
P0011(00)
Raw code: 001100
============32==============
P0010(FF)
Raw code: 0010FF
OBDII: Camshaft position (CMP) actuator, intake/left/front, bank 1 - circuit malfunction
============33==============
P0010(FE)
Raw code: 0010FE
============34==============
P0015(56)
Raw code: 001556
OBDII: Camshaft position (CMP) actuator, exhaust/right/rear, bank 1 - timing over-retarded
============35==============
P002E(89)
Raw code: 002E89
OBDII: Exhaust camshaft profile control B, bank 2 - circuit low
============36==============
P0011(E4)
Raw code: 0011E4
============37==============
P0011(E6)
Raw code: 0011E6
============38==============
P0011(E5)
Raw code: 0011E5
============39==============
P0011(E3)
Raw code: 0011E3
============40==============
P0011(E0)
Raw code: 0011E0
============41==============
P0011(E2)
Raw code: 0011E2
============42==============
P0011(E1)
Raw code: 0011E1
============43==============
P0011(DF)
Raw code: 0011DF
============44==============
P0011(DC)
Raw code: 0011DC
============45==============
P0011(DE)
Raw code: 0011DE
============46==============
P0011(DD)
Raw code: 0011DD
============47==============
P0011(DB)
Raw code: 0011DB
============48==============
P0011(DA)
Raw code: 0011DA
============49==============
P0011(D9)
Raw code: 0011D9
============50==============
P0045(06)
Raw code: 004506
============51==============
P0042(FF)
Raw code: 0042FF
OBDII: Heated oxygen sensor (HO2S) 3, bank 1, heater control - circuit malfunction
============52==============
P0015(55)
Raw code: 001555
============53==============
P0015(52)
Raw code: 001552
============54==============
P0014(98)
Raw code: 001498
OBDII: Camshaft position (CMP) actuator, exhaust/right/rear, bank 1 - timing over-advanced/system performance
============55==============
P0015(50)
Raw code: 001550
============56==============
P0015(4D)
Raw code: 00154D
============57==============
P0015(4F)
Raw code: 00154F
============58==============
P0015(4E)
Raw code: 00154E
============59==============
P0039(27)
Raw code: 003927
OBDII: Turbocharger (TC) bypass valve/supercharger (SC) bypass valve, control - range/performance problem
============60==============
P004A(07)
Raw code: 004A07
============61==============
P0015(CE)
Raw code: 0015CE
============62==============
P0015(CC)
Raw code: 0015CC
============63==============
P0027(6B)
Raw code: 00276B
OBDII: Exhaust valve control solenoid, bank 1 - range/performance problem
============64==============
P0053(DD)
Raw code: 0053DD
OBDII: Heated oxygen sensor (HO2S), bank 1, sensor 1 - heater resistance
============65==============
P001B(DD)
Raw code: 001BDD
OBDII: Intake camshaft profile control A, bank 1 - circuit low
============66==============
P0042(EC)
Raw code: 0042EC
ECU: Engine control unit[Archive (inactive)]
Status: Test failed since last DTC clear, Test not completed during this operation cycle
66 error codes: O2/Boost sensor/camshaft
Return to “MK8 and MK9 (6R/6C) Polo (inc GTI) - Years 2009-2017”
Jump to
- Polo Forums
- ↳ ID. Polo (1st Generation)
- Classifieds
- ↳ Parts For Sale
- ↳ Wheels & Tyres
- ↳ Brakes & Suspension
- ↳ Cars Breaking
- ↳ Unsorted For Sale Posts
- ↳ Cars For Sale
- ↳ Wanted
- ↳ Group Buy
- Performance & Technical
- ↳ DIY Guides
- ↳ ICE
- ↳ Chassis
- ↳ Powertrain
- ↳ Detailing / Bodywork
- ↳ Electrical
- Non-Polo Vehicles
- ↳ Seat Ibiza
- ↳ Skoda Fabia
- Polo Community
- ↳ Announcements
- ↳ Club House
- ↳ YouTube Videos
- ↳ Photography and Photoshop
- ↳ Reviews and Features
- ↳ Meetings & Events
- ↳ Meetings & Events Gallery
- ↳ Members Rides
- ↳ Was that you?
- ↳ Virtual Post Cards
- ↳ Forum Technical Help!
