I am going to upgrade from drums to discs in the near future and was wondering if the brake lines need changing or the original ones are long enough.
Also I know I need to change the handbrake, but I don't know the part number for the new one.
Upgrading from drums to discs.
- mirceaculita
- Drives: 6R 1.2TDI 75hp
patil
Re: Upgrading from drums to discs.
Brake cables, hydraulic lines all need to be changed. Hand brake part number is also mentioned in the list.mirceaculita wrote: Wed Jun 29, 2022 3:58 pm I am going to upgrade from drums to discs in the near future and was wondering if the brake lines need changing or the original ones are long enough.
I recommend you to read the CNK thread, you'll get all the information shared by firegrafik, CNK and iichel.
viewtopic.php?p=529056#p529056
- mirceaculita
And I saw there is some coding necessary, but I didn't really understand it.
What should byte 2 and 10 be changed to?
Currently they are both 24 on my car.
what is your current coding and ABS type?
- mirceaculita
I will come back with the complete answer in a few hours since I don't have a VCDS cable myself and have to go to my friend to use it.
The only thing I know is that it's an ESP8.2i module. I'm not sure if this is the type that you mentioned.
Yes esp8.1 is the type
- mirceaculita
The code that was under current coding is:
210224E3416E00B3842524E282D200421500
The coding for your LHD Polo 6R 1.2 TDI M5 with XDS, HHC and without TPMS with VIN 11001 is 210228E3416E00B3842514E282D200421500 for 256mm front discs and 232 rear discs
- mirceaculita
Thanks. The coding was accepted and everything seems to be working correctly.
