Power steering pump and reservoir location
I have a fluid leak which isn't oil an appears to look more like power steering fluid. Can anyone tell me where the 6R power steering pump is located when looking at the front of the car? also what can I check to see where it may be leaking from?
Re: Power steering pump and reservoir location
under the battery you can see a round green lid. ( aka behind fender liner) You can check the hard hoses leading towards the power steering rack they follow the chassis leg
