Brake change on polo 6r 2010
Jdarby
Drives: 2010 1.4 6r
Post by Jdarby »
Does anyone know if the 312mm brake callipers from the Octavia Vrs Mk 1 will fit onto the polo without any adapters?
Re: Brake change on polo 6r 2010
Yes, but you need different hub carrier ( the one where you can remove the pad carrier) 1.6 TDI 105hp 1.4 tsi ...
I think one topic on the subject is sufficient, I removed the other three.
