Loose Axle sound? Video incl.
Harrihealey02
Drives: 2018 SEL
Post by Harrihealey02 »
https://youtu.be/Fl58a1cNwVo
I took my car into Volkswagen numerous times for a groaning noise turning left and right sharply but they have not figured out what it is. I suspect it is the CV joint but they don’t think it is, and instead think it is the brake discs flexing. I jacked up the car and the video above shows the noises I hear when moving the wheels back and forth. There is a lot of play somewhere along the front axels on both sides, as when I hold them and move the wheels you can feel the clunking. It seems louder on the passenger side.
It has been booked in but if anyone knows what it sounds like I can tell them so that I am not waisting my time 😂
Last edited by Harrihealey02 on Sun Aug 21, 2022 2:56 pm, edited 2 times in total.
Harrihealey02
Drives: 2018 SEL
Re: Loose Axle sound? Video incl.
https://youtu.be/qD5QDagKHWQ
Here is a another problem I have with my car, the crankshaft pulley bearing is leaking oil and making a whiring sound.
