Hi All
need some help my sons vw polo has came up with 01276 ABS Hydraulic Pump V 64 error 014 -Defective-Intermittent
is this the full ABS assy needing replaced
ABS Hydraulic pump(V64)
scotspie501
- Drives: 2002
Re: ABS Hydraulic pump(V64)
That would probably be the easiest way out, yes.
scotspie501
- Drives: 2002
Hi All
for your information ,I just seen a you tube video on that error code and it pointed to one of the 3x fuses on top of the battery have history of hairline cracked
cleaned them and when I tried to remove the 2nd one split in 2
Bingo made up temp fuse with some cabling and crimps until I get correct one
result
result
Thanks, good find. I'd expect to get an error code for terminal 30 voltage instead of the ABS pump. Thanks for sharing.
