Bosch ESP 9.0i (AS) long coding troubles for WRC ecu
MIH11MI6
Drives: 6J FR 2.0TFSI CDLJ AWD
Post by MIH11MI6 »
Hi All
I am currently in the process of swapping a 2.0tsi CDLJ into my awd ibiza 6J
I have managed to get hold of a very nicely specced 7L6 2013 Ibiza Cupra loom, with Bosch ESP 9.0i already fitted.
I have managed to get the Polo WRC CDLJ ecu reading on the loom and can see it all good in VCDS. I was attempting to get the ABS coding to work, based on the info out in the world plus a WRC auto scan provided by the friendly iichel :)
However I keep getting request out of range when coding
This is the long coding i'm attempting: 21DD7885432302C184151E72C25A004D1501
Below is the coding from a successful WRC autoscan, and the ABS Software is the same
21 DD 78 85 43 28 02 C7 84 1C 1E 6A C2 56 40 4D 09 04
21 DD 78 85 43 23 02 C1 84 15 1E 72 C2 5A 00 4D 15 01
0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
I have attached my autoscan (you'll have to excuse the amount of faults currently, the loom is sitting in my office hooked up to the bare minimum
This is the VIN being recognised from the cluster on the ABS pump measuring values
https://imgur.com/uZQbnUK
Whereas the VIN on the ecu is: WVWZZZ13ZCV001199
Autoscan:
Wednesday,09,November,2022,22:36:04:32543
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
VIN: WVWZZZ13ZCV001199   License Plate:
Chassis Type: 13-VW36 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 4B 55 56 0B
VIN: WVWZZZ13ZCV001199   Mileage: 162560km-101010miles
10-Park/Steer Assist -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Malfunction 0010
44-Steering Assist -- Status: Cannot be reached 1100
4B-Multifunc. Module -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (CDL)       Labels:. 06F-907-115-CDL.clb
   Part No SW: 6R0 907 115     HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI  02 0020
   Revision: 5BH20---    Serial number:
   Coding: 040300101C070160
   Shop #: WSC 00020 790 00000
   VCID: 6FBBD9951B9AFD830E9-803A
   VINID: 9E69EAAAA043A939800010492464C7B843
20 Faults Found:
005634 - Power Supply Terminal 30
               P1602 - 002 - Voltage too Low - Intermittent
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
000291 - Throttle Position Sensor (G69)
               P0123 - 001 - Signal too High
                    Fault Status: 01100001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Absolute Pres.: 990.0 mbar
                    Voltage: 12.573 V
000546 - Angle Sensor 2 for Throttle (G188)
               P0222 - 002 - Signal Too Low
                    Fault Status: 01100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 12.573 V
008212 - Intake Manifold Flap Position Sensor (Bank 1)
               P2014 - 001 - Electrical Malfunction
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 12.573 V
000568 - Manifold Pressure / Boost Sensor (G31)
               P0238 - 001 - Signal too High
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 12.573 V
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 12.573 V
000400 - Fuel Pressure Sensor (G247)
               P0190 - 001 - Circuit Malfunction
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.573 V
005748 - Powertrain Data Bus
               P1674 - 001 - Implausible Message from Instrument Cluster
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 12.573 V
005715 - Please check DTC Memory of ABS Controller
               P1653 - 004 -
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 12.573 V
050197 - Implausible Data Received from ABS Control Module
               U0415 - 004 -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 12.573 V
049409 - No Communication with Transmission Control Module
               U0101 - 008 -
                    Fault Status: 01101000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:01
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 12.573 V
049489 - No Communications with Airbag Control Module
               U0151 - 008 -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:01
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 12.573 V
009529 - Low Pressure Fuel Sensor (G410)
               P2539 - 001 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:01
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 12.573 V
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 008 -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:01
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 12.573 V
000280 - Engine Coolant Temp. Sensor (G62)
               P0118 - 002 - Signal too High
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:01
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 12.573 V
000275 - Intake Air Temp. Sensor (G42)
               P0113 - 002 - Signal too High
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:01
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 12.573 V
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
               P2185 - 002 - Signal too High
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:01
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 12.573 V
005642 - Internal Control Module Memory
               P160A - 004 - Check Sum Error
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:01
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 12.573 V
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 001 -
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:03
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 12.573 V
049493 - No Communication with Instrument Cluster
               U0155 - 008 -  - Intermittent
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:14:38
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Voltage: 12.446 V
Readiness: 0110 0101
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H01 0002
   Serial number: --------------
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   ROD: N/A
   VCID: 0F7BB91577DA9D836E9-805A
No ASAM data for: "EV_Brake1ESP90iBOSCH" (VW36)
15 Faults Found:
0922 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Date: 2022.11.09
                    Time: 00:03:57
0983 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Date: 2022.11.09
                    Time: 00:14:37
0943 - ROD - Unknown Error Code
          - 00 [137]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
0909 - ROD - Unknown Error Code
          - 00 [137]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Date: 2022.11.09
                    Time: 00:03:57
1146 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Date: 2022.11.09
                    Time: 00:03:57
0885 - ROD - Unknown Error Code
          - 00 [129]
          MIL ON - Not Confirmed - Tested Since Memory Clear
0883 - ROD - Unknown Error Code
          - 00 [137]
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 107
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
0354 - ROD - Unknown Error Code
          - 00 [137]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Date: 2022.11.09
                    Time: 00:03:57
0364 - ROD - Unknown Error Code
          - 00 [137]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Date: 2022.11.09
                    Time: 00:03:57
0374 - ROD - Unknown Error Code
          - 00 [137]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Date: 2022.11.09
                    Time: 00:03:57
0384 - ROD - Unknown Error Code
          - 00 [137]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Date: 2022.11.09
                    Time: 00:03:57
0392 - ROD - Unknown Error Code
          - 00 [129]
0393 - ROD - Unknown Error Code
          - 00 [129]
0394 - ROD - Unknown Error Code
          - 00 [129]
0395 - ROD - Unknown Error Code
          - 00 [129]
   Component: LENKW.SENSOR  H06 0060
   Serial number: 25111204652021
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5F4D14070840B95F-802A
5 Faults Found:
332644 - Databus
          U1121 00 [008] - Missing Message
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 147
                    Voltage terminal 15: 12.30 V
                    Voltage terminal 30: 5.00 V
                    Terminal 15 status: not coded/not installed
                    Entprellzeit: 5000 ms
332660 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
117060 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
335876 - Powertrain Databus
          U0002 00 [008] - No Communications
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Voltage terminal 15: 12.40 V
335886 - Powertrain Databus
          U0001 00 [008] - Unspecified Malfunction
          [Datenbus Komfort defekt]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 147
                    Voltage terminal 30: 12.45 V
                    Terminal 15 status: On
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090     HW: 7H0 937 090
   Component: BCM PQ25 Max4 H72 0708
   Revision: B9072001    Serial number: 0531 324120174
   Coding: 3C882DE888F3250093280EF57ECB9FD80EC867E9608D3041200000020000
   VCID: 6B83CD85238201A3221-803E
12 Faults Found:
00967 - Left Turn Signals
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:03
00329 - Control Circuit for Unlocking Rear Lid
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:01
00975 - Heated Rear Window (Z1)
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:02
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:02
00077 - Windshield Wiper Stop Switch (F229)
            004 - No Signal/Communication
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 107
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:40
01134 - Alarm Horn (H12)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:04
03156 - Sensor for Anti-Theft System (G578)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:04
01326 - Control Module for Multi-Function Steering Wheel (J453)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:04
01332 - Door Control Module; Passenger Side (J387)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:04
01331 - Door Control Module; Driver Side (J386)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:04
01520 - Rain and Light Recognition Sensor (G397)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:04
03591 - Control Circuit for Horn
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:02
Address 10: Park/Steer Assist
Cannot be reached
Address 15: Airbags
Cannot be reached
   Part No SW: 6J0 920 901 C    HW: 6J0 920 901 C
   Component: KOMBI         H08 0110
   Coding: 410800
   Shop #: WSC 06403 785 00200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
   VCID: 2809F289F274EABB8F3-807C
7 Faults Found:
9453074 - Fuel Level Sensor 1
          B103E 1B [009] - Resistance Too High
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Date: 2022.11.09
                    Time: 00:22:23
13637376 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [009] - -
          [Steuergerät für Bremse: bitte Fehlerspeicher auslesen]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Date: 2022.11.09
                    Time: 00:00:05
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Motor: keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 147
                    Mileage: 0 km
                    Date: 2022.11.09
                    Time: 00:00:00
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Bremse: keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 147
                    Mileage: 0 km
                    Date: 2022.11.09
                    Time: 00:00:00
12669184 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Airbag: keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 107
                    Mileage: 162569 km
                    Date: 2022.11.09
                    Time: 00:22:23
13638912 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Lenkhilfe: keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 107
                    Mileage: 162569 km
                    Date: 2022.11.09
                    Time: 00:22:23
13639168 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Leuchtweitenregelung: keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 147
                    Mileage: 0 km
                    Date: 2022.11.09
                    Time: 00:00:00
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H72 0708
   Revision: B9072001
   Coding: 002000
   VCID: 70B9DAE90AA4E27B173-8024
5 Faults Found:
01336 - Company Data Bus for Comfort System
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:02
01321 - Control Module for Airbags (J234)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:01
01309 - Power Steering Control Module (J500)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:01
03075 - Parallel Parking Assistance Control Module (J791)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:01
00381 - Databus Instrument Cluster
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 147
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:14:38
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H08 0110
   Serial number:
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
2 Faults Found:
9456128 - Engine Control Module (ECM) not authorized
          B104A 00 [009] - -
                    Fault Priority: 1
                    Fault Frequency: 1
                    Mileage: 162569 km
                    Date: 2022.11.09
                    Time: 02:04:13
9456433 - Key
          B104B 31 [009] - No Signal
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 162569 km
                    Date: 2022.11.09
                    Time: 00:30:04
Address 44: Steering Assist
Cannot be reached
Address 4B: Multifunc. Module
Cannot be reached
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 C    HW: 7L6 907 357 C
   Component: AFS-Steuergeraet    0147
   Revision: 00H04000    Serial number:
   Coding: 2688324
   VCID: 3B233DC51F225123F21-806E
   Subsystem 1 - Part No: ID-L fehlt    Labels: ID-55-01.CLB
   Component: AFS-Lst.-Modul l    ....
   Coding: 00000255
   Subsystem 2 - Part No: ID-R fehlt    Labels: ID-55-02.CLB
   Component: AFS-Lst.-Modul r    ....
   Coding: 00000255
10 Faults Found:
02233 - Left Headlight Power Output Stage (J667)
            004 - No Signal/Communication - MIL ON
                    Fault Status: 11100100
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 107
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:24:06
                    Voltage: 12.35 V
                    Speed: 0.0 km/h
                        ABS 1
02234 - Right Headlight Power Output Stage (J668)
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 107
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:24:06
                    Voltage: 12.35 V
                    Speed: 0.0 km/h
                        ABS 1
01042 - Control Module; Not Coded
            000 - - - MIL ON
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Time Indication: 0
                        Invalid
                        Invalid
                        Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
            000 - - - MIL ON
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Time Indication: 0
                        Invalid
                        Invalid
                        Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 - - - MIL ON
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 107
                    Time Indication: 0
                        Invalid
                        Invalid
                        Invalid
01539 - Headlights Not Adjusted
            005 - No or Incorrect Basic Setting / Adaptation - MIL ON
                    Fault Status: 11100101
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 107
                    Time Indication: 0
                        Invalid
                        Invalid
                        Invalid
01312 - Powertrain Data Bus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 147
                    Time Indication: 0
                    Voltage: 12.35 V
                    Speed: 0.0 km/h
                        ABS 0
01316 - ABS Control Module
            013 - Check DTC Memory - MIL ON
                    Fault Status: 11101101
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 107
                    Time Indication: 0
                    Voltage: 12.35 V
                    Speed: 0.0 km/h
                        ABS 1
00778 - Steering Angle Sensor (G85)
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 147
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:00:14
                    Voltage: 12.35 V
                    Speed: 0.0 km/h
                        ABS 1
01317 - Control Module in Instrument Cluster (J285)
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 147
                    Mileage: 162569 km
                    Time Indication: 0
                    Date: 2017.04.01
                    Time: 00:14:38
                    Voltage: 12.21 V
                    Speed: 0.0 km/h
                        ABS 1
Address 56: Radio
Cannot be reached
End----------(Elapsed Time: 02:24, VBatt start/end: 12.4V/12.4V)-----------
I was always under the impression it checked and compared the VIN bytes in the long coding against the VIN stored in the ECU, not the IMMO, based on this am I correct in thinking I need to get the VIN corrected on the IMMO to match the ECU in order to get the long coding to match?
Thanks in advance and if anyone can help further with this it would be amazing, it's certainly a challenge to make all this stuff work together, but the hunt for a true OEM engine swap has taken me into the depths of the minds of VW engineers once again lol
Re: Bosch ESP 9.0i (AS) long coding troubles for WRC ecu
Are you sure AS is a suitable ESP module for a CDL engine?
MIH11MI6
Post by MIH11MI6 »
iichel wrote: Thu Nov 10, 2022 7:13 pm Are you sure AS is a suitable ESP module for a CDL engine?
based on the WRC autoscan you provided me, the WRC runs a BG software with AS hardware.
Guessing I'm going to need BG software?
Adresse 03: Bremsenelektronik (J104)       Labeldatei: DRV\6R0-907-37x-ESP90.clb
   Teilenummer SW: 6R0 907 379 BG    HW: 6R0 907 379 AS
   Bauteil: ESP9.0i front H03 0001
   Seriennummer: --------------
   Codierung: 21DD7885432802C7841C1E6AC256404D0904
   Betriebsnr.: WSC 01383 785 00200
   ASAM Datensatz: EV_Brake1ESP90iBOSCH 003020
   ROD: EV_Brake1ESP90iBOSCH_AU21.rod
   VCID: 040C5AA48FE7E21E54-8050
Kein(e) Fehlercode(s) gefunden.
I do think so, yes. VIN check is done with immo = cluster, not with engine control unit. But I'm doubtful it will take coding when the VIN in ECU is different from the cluster.
MIH11MI6
Post by MIH11MI6 »
iichel wrote: Sat Nov 12, 2022 4:31 pm I do think so, yes. VIN check is done with immo = cluster, not with engine control unit. But I'm doubtful it will take coding when the VIN in ECU is different from the cluster.
Agreed
So I need the different ABS pump (cheap anyway) and need to get the vin matched from cluster to ECU, I reckon I can make that happen no problem
Will keep you updated :)
Yep but that's still no guarantee you can get the coding to take, but I think it's a step in the right direction
