hi all im new to this forum.
i need some advice pleass, i own a 2010 polo 1.4 auto dsg i recently bought it of copart, at first the car was driving but had a little jerk whilst driving last night i left car running for a while as the battery was dead. so after a while i went to the car tried to put window up it wouldnt go up i switched car off , then tried starting back up but it was cutting off.
so this morning it started no rev meter working with all all dash lights active and car will not move to p.r.n mode & a light flash on gearbox and it will not lock or unlock with fob, the heaters and wipers work, i connected a diognostic unit to the car but car is not responding to it
what can this be any ideas thanks
vw polo auto problem dsg
Re: vw polo auto problem dsg
Start with a new battery...
thanks i will try this and update you
i bought a new battery today and it still has same problem ?
okay so next step, if you are sure the battery is OK and charged, is to check the fuses. all of them.
