engine codes
boomtheroom
Drives: 2014 Gt blue motion
engine codes
Post by boomtheroom »
Hi
All
Anyone know the difference between the engines CPT AND CPTA?
cheers
Re: engine codes
They are the same
boomtheroom
Re: engine codes
Hmmm Why do they have the 2 different codes>?
Re: engine codes
The a in cpta stands for the first engine in the series. Some series have multiple versions like the cbza-cbzc-cbzc etc for different power outputs from the same basic engine, 1.2 Tsi 8v in this case. The 2.0 tsi golf Mk6 R CDL engine has half the alphabet ranging from cdla to at least cdlj in the Polo R WRC.
Some engine families only have 1 version like the cfwa (ea189 1.2 tdi common rail 55kw). This is also the case for your enginr code.
A theoretical cptb engine could have a slightly higher or lower power output or in some cases emission standards. This is usually obtained by alterations in software but could also involve a slightly different turbocharger, manifolds, etc.
The newer version I believe is in this case the czea engine
boomtheroom
Re: engine codes
Do you know if the 6r and 6c use the same connections for their head units? ie.
would this work in a 6r
https://www.alpine.be/p/Products/SingleView/x803d-p6c
Re: engine codes
I don't know about that.
