I just did some maintenance around the battery and this little pipe has appeared.
It goes into the bulkhead but I'm not sure where its supposed to connect to?
Any ideas please?
Cheers...
Quick Question
Quick Question
- 20230125_105812.jpg (2.47 MiB) Viewed 3312 times
- Maarten
Re: Quick Question
Do you have a sunroof/panoramaroof?
CarbonChaos
Re: Quick Question
Does your rear washer jet work ? it looks like the washer pipe to the rear which is under the battery tray area.
Re: Quick Question
Yes water jets work and I don't have a sunroof installed.
I've removed the battery and have examined the pipe more closely.
It's not a pipe but a thick power cable. I've enclosed 2 more pictures.
The power cable has writing on it which says 'Power cable OFC'
This disappears into the bulkhead as shown in the picture.
I don't see where this would connect to?
Everything electrical is working and I'm stumped...
- 20230127_155459.jpg (2.27 MiB) Viewed 3229 times
- 20230127_155438.jpg (2.39 MiB) Viewed 3229 times
- Maarten
Re: Quick Question
Maybe previous owner had an amp in the back?
