Fault: 3x Instrument Cluster Warning Lights turn on
dazz
Drives: Polo 6R Comfort Line 2010
Post by dazz »
Hi
I have an intermittent fault.
The symptoms are that the transmission thuds (as if it has shifted into the wrong gear) and 3 warning lights simultaneously light up and stay on.
The lights are:
  • ABS
  • Low tyre air pressure,
  • ESP/ASR (Electronic Stabilization Program/Anti-Slip Regulation)
Turning the engine off/on usually clears the lights.
After the initial thud, the car drives normally.
Any suggestions on what the root cause could be?
Re: Fault: 3x Instrument Cluster Warning Lights turn on
Best thing is to read the abs controller for any errors. Might be something as small as a wheel speed sensor
