Page 1 of 2
Polo 1.2 TSI Disc/pads combo
Posted: Fri Feb 10, 2023 6:11 pm
by Le_Combattant
Hey fox, what's up ?
My little girl pass sucessfully today the 120 000 km check up and my wallet lightened up of 822 euros...
But my dealer calls me to advise me that my front disc (they are original) and pads are worn out and rear pads also.
For this operation, they asked to me...700 euros.
What a joke.
So I went to the dealer and ask for an estimate.
Around 555 euros of parts, including 4 brakes pads, 4 disc, and the dedicated screws.
Now I'm looking on internet, but I a little bit lost abour brands.
I heard about Brembo, TRW etc...
Re: Polo 1.2 TSI Disc/pads combo
Posted: Fri Feb 10, 2023 6:34 pm
by iichel
I'm a big fan of ATE and TRW. Ate pads on TRW discs.
There are several other good brands like Brembo, Zimmermann, bosch, ebc as well. I'm sure you'll manage to so with about half the costs the dealer proposed.
Posted: Fri Feb 10, 2023 6:36 pm
by Le_Combattant
After some research, ATE seems the orginal fitted pars on Polo.
The Brand appears in the ETKA
Posted: Fri Feb 10, 2023 7:15 pm
by amer6R
Brembo, they dont have anti rust coating ugly after a while. I could.swear that they are 1:1 as ferodo
id pick ate/ zimmerman/ bosch
Posted: Fri Feb 10, 2023 7:49 pm
by Bepis
+1 for ATE discs. From what I've heard zimmerman also have a very good anti-corrosion coating but not tried them yet myself.
I'd avoid Textar discs as even my Textar Pro+ rear discs started to show signs of corrosion within a month after fitting.
Posted: Fri Feb 10, 2023 8:01 pm
by 2226
Running Ferodo. Did the front discs and pads, all Ferodo, on my 2017 1.2TSI with 288mm discs for just under 100 Euro.
I'm sure pricing is similar over in Europe.
Dealerships are complete rip-off artists.
Back in the day Audi/VW part pricing seemed to line up with aftermarket availability. They'd charge more for items that were easily available aftermarket because they could shift those off the shelf. I guess today they just charge stupid amounts for everything.
Posted: Fri Feb 10, 2023 8:23 pm
by Le_Combattant
2226 wrote: Fri Feb 10, 2023 8:01 pm Running Ferodo. Did the front discs and pads, all Ferodo, on my 2017 1.2TSI with 288mm discs for just under 100 Euro.
288 brakes ? What the hell.
You are the second guy I'm talking with and having 288 brakes on his Polo.
It was an option ? Mine are 256mm.
For 210 euros I have from ATE
-4 brakes discs
-4 ceramics brakes pads.
Some times VW parts are cheaper than on market, and some time you have to sell a part of your body for a stupid part made of plastic.
Posted: Fri Feb 10, 2023 9:21 pm
by iichel
288mm Is standard on blue gt and 105,hp tdi/tsi
Posted: Sat Feb 11, 2023 10:13 am
by Le_Combattant
iichel wrote: Fri Feb 10, 2023 9:21 pm 288mm Is standard on blue gt and 105,hp tdi/tsi
Oooooh feels nice.
I found quite easly front brake pads from ATE.
But rears ones are nightmare.
Lot of part number and on my PR list, nothing.
My dealer share my according my VIN for rear this part number: 5K0 698 451B
Posted: Sat Feb 11, 2023 12:08 pm
by amer6R
should be
ATE 13.0460-2820.2
or if its version with metal shims
ATE 13.0460-2894.2
ofc. there is going to be normal pad and ceramic one.
You can peek thru the wheel to see if there is a shim on caliper carrier or not.
Ceramic pads will produce less dust
I bought bosch the other day, ( version with no shims)
maybe it comes in handy to cross reference the part numbers
Made in China :|
Posted: Sat Feb 11, 2023 2:10 pm
by Le_Combattant
I hhave pictures for the rear brake pads, and yes, they are original ones :roll:
What is the purpose of the metal shims ?
Less friction between the pads and brake caliper ?
Mine doesn't have, but I don't know if it's possible to fit this system on mine.
Posted: Sat Feb 11, 2023 2:24 pm
by iichel
The shims are for noise reduction when you reverse.
Posted: Sat Feb 11, 2023 2:31 pm
by Le_Combattant
iichel wrote: Sat Feb 11, 2023 2:24 pm The shims are for noise reduction when you reverse.
When I reverse ? Could you explaine to me how it works ?
Do you think I could install this shims even they are not fitted from the factory ?
I check my PR code, and no information about that.
Posted: Sat Feb 11, 2023 3:46 pm
by iichel
yes you can install the shim at any time, even if you don't have it from factory.
Posted: Sat Feb 11, 2023 5:07 pm
by Le_Combattant
iichel wrote: Sat Feb 11, 2023 3:46 pm yes you can install the shim at any time, even if you don't have it from factory.
Okey thanks for your help !
Final order is:
4 Brakes disc:
-24.0122-0151.1 x2
-24.0109-0123.1 x2
2 set of brakes pads:
-13.0460-7111.2
-13.0460-2894.2
Total: 182 euros.
All from ATE.
