Daft question
lancslad1985
Daft question
This will be a stupid question so I apologise. Whilst I know a lot about car cleaning, I’m a completely novice at anything mechanical. Are these the correct wipes for the current polo?
- 6CDA04A6-F91A-44FB-8262-EEFF6A9CB7E9.png (821.89 KiB) Viewed 1582 times
- Maarten
Re: Daft question
For the LHD countries it is the A863S
650mm driver side
450mm passenger side
Maybe there is a difference between the LHD and the RHD
650mm driver side
Re: Daft question
Assuming the pre and post facelift models have the same wiper blades, they look to be the correct ones. Bosch Aerotwin wiper blades for my 2020 GTI+ are;
Front; A864S
Rear; A282H
Remember to lay a thick towel or something similar on the screen when removing the old blades and fitting the new ones; if the wiper arm falls onto the screen without the blade attached it can crack the windscreen.
Front; A864S
Rear; A282H
lancslad1985
Re: Daft question
SRGTD wrote: Wed Mar 15, 2023 9:07 am Assuming the pre and post facelift models have the same wiper blades, they look to be the correct ones. Bosch Aerotwin wiper blades for my 2020 GTI+ are;
Front; A864S
Rear; A282H
These are the codes that came up for mine, so as it’s a facelift I assume it’s the same. Cheers both and thanks for the handy tip SRGTD. Hoping these are better than the standard ones which are useless now after winter.
- Maarten
Re: Daft question
Put the wiperarms in service mode before changing tooSRGTD wrote: Wed Mar 15, 2023 9:07 am Assuming the pre and post facelift models have the same wiper blades, they look to be the correct ones. Bosch Aerotwin wiper blades for my 2020 GTI+ are;
Front; A864S
Rear; A282H
contact on and then off
push wiperhandel down 1 time
wipers will stop at the top of the frontwindow
Use the wipers one time to let them return to their usual positions
lancslad1985
Re: Daft question
Thanks Maarten. Thankfully I knew that one from cleaning the car.
Re: Daft question
On the AW (pre-facelift) Polo, it’s possible to lift the wiper arms away from the windscreen without putting them into the service position and they don’t make contact with the edge of the bonnet. Assume the same would also be the case with the BZ (facelift) model.
- Maarten
Re: Daft question
Is the facelift called BZ?
On topic, yes they do not touch the bonnet without putting in service mode (FL model)
Re: Daft question
Yes, indeed it is.
- Maarten
Re: Daft question
Never knew that, always saw AW or 2G
