Hello guys
The stock shock absorbers will be changed soon. Does anyone know if there's any problem with the sport button? I know that sport button makes the suspension stiffer but is it attached to the stock shocks or will it work with any set of shocks available on the market for this car?
Thanks!!
gti 6c shocks and sport button
chrispolymer
- Drives: Polo gti 6c
Re: gti 6c shocks and sport button
If your car has dynamic damping, then yes new dampers would also need to have dynamic functionality.
Dink
- Drives: 2015 GTI
unfortunatly you can't get dampers to work with the sport button.
so you will get a damper fault on the dashboard if you don't get the delete kit
the delete kit is best part of £300
I have made a delete module to clear the fault that i sell if you want to take a look https://www.ebay.co.uk/itm/204248142036
