Polo RHD door connector
Posted: Mon Mar 20, 2023 11:57 am
by morbid80
Hi all. Appreciate it if someone kind enough to share some detail pictures of a RHD polo driver right front door connector T28 and T28a. If possible,showing all wires from each pin out.
I am doing a rewiring for a suspected botch job
Re: Polo RHD door connector
Posted: Mon Mar 20, 2023 1:34 pm
by patil
Posted: Mon Mar 20, 2023 3:27 pm
by morbid80
patil wrote: Mon Mar 20, 2023 1:34 pm
Thanks bro!
What i mean is, pictures like this, for me to compare
Posted: Mon Mar 20, 2023 5:30 pm
by ciclo
6R. Convenience System, RHD, (LOR). Europe.T28, T28a, etc...
PDF:
https://drive.google.com/file/d/1ecyUvf ... sp=sharing
Posted: Tue Mar 21, 2023 5:57 am
by morbid80
Posted: Tue Mar 21, 2023 6:36 pm
by ciclo
6R WD (PDF)
Maybe you need some more information about the wires that reach the T28 and T28a connectors, you will find it in the following PDF:
https://drive.google.com/file/d/0B2nv91 ... KxQGUiXrgA
Posted: Thu Mar 23, 2023 3:45 am
by morbid80
Perfect master Ciclo! got everything i need now.Big thanks to you and Mr. Patil!
Posted: Sun Apr 02, 2023 3:01 am
by morbid80
so as i suspected, the car had both driver side front and driver rear door changed.but a lower spec polo's doors was used.as a result, i have this issues
1)no heating/ folding function due to no wiring & inferior WRM
2)no safelock due to no wiring & inferior door lock module
i have managed to add the required wiring for both issues, thanks to Wiring Diagram provided by master Ciclo.
for issue no.1, i have bought the appropriate WRM model that comes originally with this car.(6R0 959 802 AC for Front right driver door / 6R0 959 812 G for right rear door)
i have successfully got the folding side mirrors and heating function back.
but now i have one issue whereby the window switch on driver's door is controlling opposite side of FRONT window only(i.e front right window button operating front left window and vice versa).
it works correctly for rear windows. i suspect it have something to with coding.
hopefully someone can help.
Chassis Type: 6R-VW25 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 2E 44 55 56
VIN: WVWZZZ6RZDY048095 Mileage: 115720km-71905miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAVE) Labels:. 03C-907-309-V1.clb
Part No SW: 03C 906 027 AR HW: 03C 906 027 AR
Component: 1.4l R4 TSI H15 9971
Revision: L2H15--- Serial number: CVN: 258D82A9
Coding: 00250012002400000000
Shop #: WSC 26180 002 1048576
ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
ROD: EV_ECM14TSI01103C906027AR.rod
VCID: 71BFD5D9012AE45314C-8024
VINID: 9E69EAAAA1A2A94A401080091499B35A42
Readiness: 1110 0101
Part No SW: 0AM 300 058 P HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6217
Revision: 00043014 Serial number: 5ZV01205140663
Coding: 0000020
Shop #: WSC 00046 000 00000
VCID: 3E253EE50C744B2BD9E-806A
Address 03: ABS Brakes
Cannot be reached
Component: LENKW.SENSOR H06 0060
Serial number: 090465LGA00106
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5FEE540748B2B99E-802A
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 382928FD2250751B132-806C
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 089 F HW: 7H0 937 089
Component: BCM T5GP Li4 H50 0254
Revision: BS050001 Serial number: 0465 180120962
Coding: 2CB02BBF08A10000093808D16E2B0FD05AC0676F60051041200000010000
Shop #: WSC 00788 648 00255
VCID: 392F2DF9195A6C13ECC-806C
Subsystem 1 - Part No: 1K0 955 559 AH
Component: RLS 260612 05 54 0403
Coding: 02302D
Subsystem 2 - Part No SW: 6R0 959 802 AC HW: 6R0 959 802 AC
Component: J386__TSG_FT 008 1611
Serial number: KU0KU021061100012639
Coding: 18BC34
Subsystem 3 - Part No SW: 6R0 959 801 AE HW: 6R0 959 801 AE
Component: J387__TSG_BT 008 1611
Serial number: KU0KU019031200013496
Coding: 18BC34
Subsystem 4 - Part No SW: 6R0 959 591 B HW: 6R0 959 591 B
Component: J245 PS72.023 H02 0007
Serial number: WOO16824656
Coding: 081001
Subsystem 5 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B
Component: E221__MFL-TAS H30 0032
Serial number: 0047459
Coding: 830000
Subsystem 6 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU013061200012870
Coding: 18BC32
Subsystem 7 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU009081100010283
Coding: 18BC32
2 Faults Found
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 22
Mileage: 115721 km
Time Indication: 0
Date: 2017.08.23
Time: 09:01:26
03432 - Activation of Right Parking Light
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 22
Mileage: 115721 km
Time Indication: 0
Date: 2017.08.23
Time: 09:01:26
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361217401067
Coding: 108104
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E253EE500F44B2BD9E-806A
Part No SW: 6R0 959 655 M HW: 6R0 959 655 M
Component: VW10Airbag01E H10 0020
Revision: -------- Serial number: 003GZ0013BN6
Coding: 003145
Shop #: WSC 01383 785 00200
VCID: 4CC1642D4648E9BB47A-8018
Serial number: 3575HRB405N15IRQF0QA
Serial number: 3585HRB405F1F0BADODF
Serial number: 3515RRB400G4UJ4QH0B
Serial number: 3525RRB400G4UJ4Q9PMO
Part No SW: 6R0 920 870 B HW: 6R0 920 870 B
Component: KOMBI H04 0605
Coding: 140E01
VCID: 34311CCD3EB8917B3FA-8060
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 089
Component: GW-K-CAN TP20 H50 0254
Revision: BS050001
Coding: 002300
VCID: 70B9D0DD0AA0ED5B1B2-8024
Component: IMMO H04 0605
Serial number:
VCID: 6A8DC2B52CFC178B556-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7663076900
Coding: 010100
VCID: 2A0D02B5ECFCD78B956-807E
Address 44: Steering Assist
Cannot be reached
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0116000001000000
VCID: 77ABEBC16F4EBA63DA8-8022
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
Component: Radio RCD510 005 0234
Revision: 00000001 Serial number: VWZ1Z3M7254695
Coding: 01000400020001
VCID: 2411EC8D8ED801FBAFA-8070
End----------(Elapsed Time: 02:08, VBatt start/end: 12.2V/12.2V)-----------
Posted: Tue Apr 04, 2023 7:10 pm
by ciclo
Maybe this coding info will help you to fix it:
Posted: Tue Apr 04, 2023 7:27 pm
by ciclo
Here is an Autoscan of a 6R RHD of approximately the same build dates:
viewtopic.php?p=538483#p538483
Posted: Thu Apr 06, 2023 3:07 am
by morbid80
Thank you for your help again!
Just to update, i found out what is wrong.the wiring in the window switch’s connector was tampered with. Front window Left(t10j/6) and right (t10j/5) switch wire were swapped. Comparing mine with online pictures has help me as WD is confusing(both left and right labelled as t10j/5 )
I swapped them back and now they are working as it should.
- E8007292-41DD-4B44-B498-213AE32A6FB1.jpeg (204.45 KiB) Viewed 2615 times
Original wiring
- 15B7B8EB-5365-434B-8A6A-D83BA6BC6BF2.jpeg (2.04 MiB) Viewed 2615 times
My botched wiring
- F9FBCE8A-4317-4F98-8AA9-F87B967DD23B.jpeg (107.84 KiB) Viewed 2615 times
Confusing label
Posted: Thu Apr 06, 2023 6:40 am
by ciclo
Well done!!
Study and meditation help us improve.
It is not the first time in this and other forums that we have found 'printing errors'
in the W diagrams...
