Polo RHD door connector
morbid80
Drives: polo gti
Post by morbid80 »
Hi all. Appreciate it if someone kind enough to share some detail pictures of a RHD polo driver right front door connector T28 and T28a. If possible,showing all wires from each pin out.
I am doing a rewiring for a suspected botch job
patil
Re: Polo RHD door connector
Post by patil »
morbid80
Drives: polo gti
Post by morbid80 »
patil wrote: Mon Mar 20, 2023 1:34 pm Image
Thanks bro!
What i mean is, pictures like this, for me to compare
6R. Convenience System, RHD, (LOR). Europe.T28, T28a, etc...
PDF: :arrow: https://drive.google.com/file/d/1ecyUvf ... sp=sharing
morbid80
Drives: polo gti
Post by morbid80 »
ciclo wrote: Mon Mar 20, 2023 5:30 pm 6R. Convenience System, RHD, (LOR). Europe.T28, T28a, etc...
Thank You!
6R WD (PDF)
Maybe you need some more information about the wires that reach the T28 and T28a connectors, you will find it in the following PDF:
https://drive.google.com/file/d/0B2nv91 ... KxQGUiXrgA
morbid80
Drives: polo gti
Post by morbid80 »
Perfect master Ciclo! got everything i need now.Big thanks to you and Mr. Patil!
morbid80
Drives: polo gti
Post by morbid80 »
so as i suspected, the car had both driver side front and driver rear door changed.but a lower spec polo's doors was used.as a result, i have this issues
1)no heating/ folding function due to no wiring & inferior WRM
2)no safelock due to no wiring & inferior door lock module
i have managed to add the required wiring for both issues, thanks to Wiring Diagram provided by master Ciclo.
for issue no.1, i have bought the appropriate WRM model that comes originally with this car.(6R0 959 802 AC for Front right driver door / 6R0 959 812 G for right rear door)
i have successfully got the folding side mirrors and heating function back.
but now i have one issue whereby the window switch on driver's door is controlling opposite side of FRONT window only(i.e front right window button operating front left window and vice versa).
it works correctly for rear windows. i suspect it have something to with coding.
hopefully someone can help.
Chassis Type: 6R-VW25 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 2E 44 55 56
VIN: WVWZZZ6RZDY048095   Mileage: 115720km-71905miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAVE)       Labels:. 03C-907-309-V1.clb
   Part No SW: 03C 906 027 AR    HW: 03C 906 027 AR
   Component: 1.4l R4 TSI   H15 9971
   Revision: L2H15---    Serial number:                CVN: 258D82A9
   Coding: 00250012002400000000
   Shop #: WSC 26180 002 1048576
   ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
   ROD: EV_ECM14TSI01103C906027AR.rod
   VCID: 71BFD5D9012AE45314C-8024
   VINID: 9E69EAAAA1A2A94A401080091499B35A42
Readiness: 1110 0101
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 058 P    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6217
   Revision: 00043014    Serial number: 5ZV01205140663
   Coding: 0000020
   Shop #: WSC 00046 000 00000
   VCID: 3E253EE50C744B2BD9E-806A
Address 03: ABS Brakes
Cannot be reached
   Component: LENKW.SENSOR  H06 0060
   Serial number: 090465LGA00106
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5FEE540748B2B99E-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 382928FD2250751B132-806C
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 089 F    HW: 7H0 937 089
   Component: BCM T5GP Li4  H50 0254
   Revision: BS050001    Serial number: 0465 180120962
   Coding: 2CB02BBF08A10000093808D16E2B0FD05AC0676F60051041200000010000
   Shop #: WSC 00788 648 00255
   VCID: 392F2DF9195A6C13ECC-806C
   Subsystem 1 - Part No: 1K0 955 559 AH
   Component: RLS 260612 05  54  0403
   Coding: 02302D
   Subsystem 2 - Part No SW: 6R0 959 802 AC    HW: 6R0 959 802 AC
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU021061100012639
   Coding: 18BC34
   Subsystem 3 - Part No SW: 6R0 959 801 AE    HW: 6R0 959 801 AE
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU019031200013496
   Coding: 18BC34
   Subsystem 4 - Part No SW: 6R0 959 591 B    HW: 6R0 959 591 B
   Component: J245 PS72.023  H02 0007
   Serial number:     WOO16824656
   Coding: 081001
   Subsystem 5 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B
   Component: E221__MFL-TAS  H30 0032
   Serial number: 0047459
   Coding: 830000
   Subsystem 6 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU013061200012870
   Coding: 18BC32
   Subsystem 7 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU009081100010283
   Coding: 18BC32
2 Faults Found
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 22
                    Mileage: 115721 km
                    Time Indication: 0
                    Date: 2017.08.23
                    Time: 09:01:26
03432 - Activation of Right Parking Light
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 22
                    Mileage: 115721 km
                    Time Indication: 0
                    Date: 2017.08.23
                    Time: 09:01:26
Address 10: Park/Steer Assist (J446)       Labels:* None
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361217401067
   Coding: 108104
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E253EE500F44B2BD9E-806A
   Part No SW: 6R0 959 655 M    HW: 6R0 959 655 M
   Component: VW10Airbag01E H10 0020
   Revision: --------    Serial number: 003GZ0013BN6
   Coding: 003145
   Shop #: WSC 01383 785 00200
   VCID: 4CC1642D4648E9BB47A-8018
   Serial number: 3575HRB405N15IRQF0QA
   Serial number: 3585HRB405F1F0BADODF
   Serial number: 3515RRB400G4UJ4QH0B
   Serial number: 3525RRB400G4UJ4Q9PMO
   Part No SW: 6R0 920 870 B    HW: 6R0 920 870 B
   Component: KOMBI         H04 0605
   Coding: 140E01
   VCID: 34311CCD3EB8917B3FA-8060
   Part No SW: 6N0 909 901     HW: 7H0 937 089
   Component: GW-K-CAN TP20 H50 0254
   Revision: BS050001
   Coding: 002300
   VCID: 70B9D0DD0AA0ED5B1B2-8024
   Component: IMMO          H04 0605
   Serial number:
   VCID: 6A8DC2B52CFC178B556-803E
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7663076900
   Coding: 010100
   VCID: 2A0D02B5ECFCD78B956-807E
Address 44: Steering Assist
Cannot be reached
   Revision: --------    Serial number: --------------
   Coding: 0116000001000000
   VCID: 77ABEBC16F4EBA63DA8-8022
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
   Component: Radio RCD510  005 0234
   Revision: 00000001    Serial number: VWZ1Z3M7254695
   Coding: 01000400020001
   VCID: 2411EC8D8ED801FBAFA-8070
End----------(Elapsed Time: 02:08, VBatt start/end: 12.2V/12.2V)-----------
Maybe this coding info will help you to fix it:
Here is an Autoscan of a 6R RHD of approximately the same build dates:
viewtopic.php?p=538483#p538483
morbid80
Drives: polo gti
Post by morbid80 »
ciclo wrote: Tue Apr 04, 2023 7:27 pm Here is an Autoscan of a 6R RHD of approximately the same build dates:
Thank you for your help again!
Just to update, i found out what is wrong.the wiring in the window switch’s connector was tampered with. Front window Left(t10j/6) and right (t10j/5) switch wire were swapped. Comparing mine with online pictures has help me as WD is confusing(both left and right labelled as t10j/5 )
I swapped them back and now they are working as it should.
Original wiring
My botched wiring
Confusing label
Well done!!🥇👌 Study and meditation help us improve. :lol:
It is not the first time in this and other forums that we have found 'printing errors' :mrgreen: in the W diagrams...
