tick over rev increase in sport mode gti
LEEA123
Drives: none
Post by LEEA123 »
Hi all, not sure if this is just a glitch or something I should keep my eye on, as a potential future issue. So when I go from D- S mode for example when stationary the revs increase a little, which is correct. Once or twice when going into S mode the tick-over has not increased, but driving in S mode is fine. Still getting S on dash and gear changes correct for S mode.
Only had it a couple of times, So am asking is it just a software glitch that it has not increased tick-over when stationary or the start of an issue that may need to inform vw about .?
Drives in S mode fine when this has happened and the tick-over goes to its slightly higher rev when stopping again. Just a couple of times its happened when first selected sport mode before moving. Thank you
Re: tick over rev increase in sport mode gti
My TSI engined Passat does the same
LEEA123
Drives: none
Post by LEEA123 »
iichel wrote: Tue Apr 18, 2023 4:14 pm My TSI engined Passat does the same
thank you for the reply
