6R/6C Cross Polo rear cross member / stiffener
Post by 2226 »
I'm in need of a new rear cross member / crash bar / stiffener that goes under the rear bumper.
Car was rear-ended on Wednesday this past week. Cracked bumper cover and the stiffener / crash bar is caved in.
While looking for used one I found this:
What vehicle is this from?
The part on the car doesn't look anything like that. Waiting for more photos and maybe a part number, but just curious if anyone can identify this one. I don't think it's from the 9N Cross Polo either.
Photo of the damage:
I think that sheet metal under the right mount has folded slightly over to the left. The cross member arm doesn't seem to point straight. Can't quite tell since the bodywork isn't symmetrical under there.
Re: 6R/6C Cross Polo rear cross member / stiffener
that not polo 6r for sure
polo has only 1 bolt hole on the bottom and the flange is completely flat, your part on picture has two(3) and its not flat.
given the seller oriented it correctly
- still tho its not flat on mating surface.
Conntact seller to double check the part number
2226
Post by 2226 »
Waiting for photos. Very curious as to what it is from.
