PDC retrofit. Front sensors & harness part numbers?
wide23
Drives: Polo 6R
Post by wide23 »
Hello,
I would like to add park distance control system to my Polo 6R 2013.
I started digging. I know that on aliexpress and others sellers offer full kit PDC system but I want to check if I can collect all part myself.
As I know, I need:
Buzzer: 8E0 919 279
PDC module: 6R0 919 475 C
Rear sensors: 1S0 919 275 C
Sensor holders: 6R0 919 491 D and 6R0 919 491 E
Rear bumper sensors wiring: 6R0 971 065
As I think missed are:
1. Harness to connect PDC module with car – is it OE harness or custom? I found on carsystem.er but not in ETKA.
2. Harness between PDC module and rear bumper harness (Am I right?) – I found on carsystem.eu but not in ETKA
3. Front sensors and harness – I can’t even find diagram in ETKA with front bumper/sensors. Exist? (found on carsystem.eu). Or people using wiring and sensors from another car models? Polo 6C? Sensors: 1S0 919 275 or 1S0 919 275 C ?
4. Harness between front bumper harness and PDC module?
If I’m wrong, please let me know how it looks like with part numbers.
Best regards
Re: PDC retrofit. Front sensors & harness part numbers?
the front and rear PDC bumper harness is almost the same, but the connector is in the middle a the rear and at the side, for the front setup.
perhaps you can use harness i.e. from mk6 golf?
all other harnesses must be made by yourself or from carsystems, i don't think VW has an OEM kit for it.
